Old 09-09-2015, 04:56 AM   #1
chazlll
chazlll's Avatar
another small block header question!
I'm running a 350 small block with a set of trick flow G1 heads in my 66 GMC. 1/2 ton 2wheel drive.
The problem is that I have the forward mounts & angle plugs.
Can any one help.
Summit racing sent me set & said that they would work but they hit the frame.
If you can tell me what you are running & how much you had to do to make them work.
chazlll is offline   Reply With Quote
Old 09-09-2015, 10:14 AM   #2
siggyfreud
siggyfreud's Avatar
Re: another small block header question!
I also have trickflows with angle plugs in my 66. When I get to work I'll look up the part number of the headers I use that work and send it your way.
siggyfreud is offline   Reply With Quote
Old 09-09-2015, 10:14 AM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Looks like you got your answer.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-09-2015, 11:53 AM   #4
siggyfreud
siggyfreud's Avatar
Here is what I ordered and they fit my SBC. My SBC is also moved forward a bit compared to the stock location.
http://www.summitracing.com/parts/HED-69890
Old 09-09-2015, 11:39 PM   #5
Captainfab
60-66 Nut
Looking at pics in your build thread, will a 90* boot work on #5 or is a straight boot needed?
Old 09-10-2015, 12:52 AM   #6
siggyfreud
siggyfreud's Avatar
For these headers a straight is needed for 5. When I made the wires I made then for the old headers, but those hit the frame/crossmember. I'm not crazy about the routing of #6 and will try and clean it up a bit to be inside the header. OP if you look at page 2 of my build thread you can see the headers on the engine.
