Old 09-09-2015, 11:57 AM   #1
poncho65
poncho65's Avatar
Speedo Gear O-ring or not?
So I pulled my speedo gear out of the transmission tail shaft this weekend to have a look. The gear looks good and appears to function fine....should there be an o-ring between the nut and the threads where the gear attaches to the tail shaft? I did not see an o-ring when I removed the gear. The gear had a dab of green paint on it....would that indicate the gear size/ratio?
1962 Cheverlot C-10 (1/2-ton short-step) 4-speed, original paint. (Oakland built).
1965 Pontiac GTO convertible, 4-speed with tri-power. (Freemont built).
poncho65 is offline   Reply With Quote
