Old 09-09-2015, 03:31 PM   #1
bean
wiring question
Replacing my worn out 350 with a low milrage mid 80s model 305. Question is how do the old wires attach to the new starter now? Thanks
bean is offline   Reply With Quote
Old 09-09-2015, 04:11 PM   #2
bean
Re: wiring question
How do the wired connect to the later model sollenpid?
Old 09-09-2015, 08:51 PM   #3
bean
Re: wiring question
The solenoid on old starter had 2 terminals nrw ome has 1....
Old 09-09-2015, 09:47 PM   #4
firedemon
Re: wiring question
the second wire on the r terminal is for a points distributor the s is for the start from the key. if you have hei you don't need the r terminal if you have points you should be able to switch solonoids on the starter
firedemon is offline   Reply With Quote
