Old 09-09-2015, 08:55 PM   #1
3/4 GMC
4x4 big block??
Hello, I am new to the site. I am building from ground up a 1972 3/4 ton 4x4. As of date every thing under the truck has been powder coated, including the bottom of the bed pan and cab. We even went as far as to powder coat the fire wall inside and out. I am wanting to build this as a big block. Do you think this will hurt the end result or help it. Any thoughts?
3/4 GMC is offline   Reply With Quote
Old 09-09-2015, 09:03 PM   #2
cleszkie
cleszkie's Avatar
Re: 4x4 big block??
If you go with a bib block, I think you will need to make some modifications to your firewall that you already powdercoated, in order to make it fit. There are a few old threads out there on the process of fitting a big block into a 4x4. Do a search and see what you find.
cleszkie is offline   Reply With Quote
Old 09-09-2015, 09:41 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 4x4 big block??
How can an engine "hurt the end result"? Not sure I understand the question... It's your truck. Build it as you see fit.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-09-2015, 09:55 PM   #4
Re: 4x4 big block??
The engine won't hurt the value any more than all that powder coating.But it's true, the firewall requires modification to fit a big block
Old 09-09-2015, 10:05 PM   #5
jocko
jocko's Avatar
Re: 4x4 big block??
agree with Tim - if concerned about originality because K's never came with big blocks from the factory, the pc negates all that. You've already kissed her, ya might was well marry her. Big Block!
Old 09-09-2015, 11:31 PM   #6
geunther
geunther's Avatar
Re: 4x4 big block??
I had a 72 Blazer and was able to install a BB without any firewall modifications. It was very tight and if I remember correctly I had to use stock valve covers in order to clear. Aluminum covers would not clear so thats how tight it was.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 09-09-2015, 11:33 PM   #7
englands 71
englands 71's Avatar
Re: 4x4 big block??
englands 71 is offline   Reply With Quote
Old 09-10-2015, 02:00 AM   #8
PeterHall
Re: 4x4 big block??
We're using a 4l80e and adapter to a np205. this combo pushed the engine forward enough for plenty of clearence on the cab.
PeterHall is offline   Reply With Quote
Old 09-10-2015, 03:56 AM   #9
72again4x4
72again4x4's Avatar
Re: 4x4 big block??
Hi 3/4GMC,
I'm with PeterHall, I have a 72 K10, BB396 and there is no firewall clearance issues. The HEI isn't going anywhere without pulling the motor though.
Good luck, sounds like a great project.
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 09-10-2015, 09:47 AM   #10
3/4 GMC
Re: 4x4 big block??
Not to sound stupid but I am, what is 4180E and adapter to a np205 is that the motor mount?
Old 09-10-2015, 10:10 AM   #11
3/4 GMC
Re: 4x4 big block??
Originally Posted by 72again4x4 View Post
Hi 3/4GMC,
Roger
May I ask what motor mounts you used? And Thanks its been fun so far
Old 09-10-2015, 10:37 AM   #12
57taskforce
All about them K’s
57taskforce's Avatar
Re: 4x4 big block??
The 4l80e is the overdrive version of the turbo 400 transmission and it requires an adapter to mate to the original np 205 transfer case in your truck.
Tyler
57taskforce is offline   Reply With Quote
Old 09-10-2015, 05:42 PM   #13
72again4x4
72again4x4's Avatar
Re: 4x4 big block??
3/4GMC, I can get some crappy cell phone pics of both mounts and the cab clearance if you like. The PO put the motor in and did a great job. I don't know exactly what mounts they are, sorry no help.
Shoot me a pm with email address and I'll send better pics if you like.
Roger
