Old 09-10-2015, 09:17 AM   #1
mgkgmc
mgkgmc's Avatar
Throttle linkage 6cyl to V8
I'm almost complete with my 6 cyl to v8 swap on my 70 GMC. I was wondering is there a different setup for the throttle linkage for a V8 then the 6 cyl because my throttle rod extends through the fire wall. I'm having problems trying to find a way to hook up my universal throttle cable to my throttle linkage. Looks like the throttle cable is supposed to go through the fire wall and my set up is already in front of it. Also I'm running a Holley 670 avenger carb. Any help will be appreciated Thanks!
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 09-10-2015, 09:44 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Throttle linkage 6cyl to V8
I need some clarification. A 1970 would have been equipped with a throttle rod, but you also mention a cable. Which way are you planning to go? If it's going to be a rod, I think all you may need is a correct length rod (not sure they were different). I also have a 670 Avenger on my 1969 with a GM crate 350 using the original 350 rod. I may have a spare you can have (free) if there's a reasonable way to mail it.
Jim
FirstOwner69 is offline   Reply With Quote
Old 09-10-2015, 09:54 AM   #3
mgkgmc
mgkgmc's Avatar
Thanks for the reply maybe that's what I need a stock throttle rod. It looks like if I used a cable it would be very short. If your willing I could give that a try.
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
Old 09-10-2015, 10:07 AM   #4
FirstOwner69
I'm willing. However, it'll be a few days since I'm 140 miles from my parts stash. I can also post some pics. I did have to put a slight bend in my throttle rod to compensate for a Lokar kickdown switch bracket I fabricated or my TH400. What transmission are you running?
Jim
Old 09-10-2015, 10:11 AM   #5
FirstOwner69
Can you post a pic of the linkage coming through the firewall from your accelerator if you are not sure it was set up for a rod?
Jim
Old 09-10-2015, 10:17 AM   #6
mgkgmc
mgkgmc's Avatar
I'm going to run a 700r4 I have the detent cable hooked up right now to the Holley bracket but I might have to modify the rear bracket by removing the throttle cable portion of it to use a rod. I will post pictures later today because I'm at work at the moment. I do believe now it set up for a rod since the throttle pedal bracket/rod passes through the firewall.
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
Old 09-10-2015, 11:58 AM   #7
michael bustamante
michael bustamante's Avatar
i have this same exact setup on my 67, text me tonight and i can send you a pic of my whole set up.
505-907-6836
700r tranny 350 motor with a holley intake and avenger carb
1967custom
michael bustamante is offline   Reply With Quote
Old 09-10-2015, 12:10 PM   #8
dzbowtie
dzbowtie's Avatar
My 70 c10 was originally inline 6, but I swapped in a v8. The factory throttle linkage was a solid rod mounted to the fire wall that pivoted off the pedal. I made my own linkage with a piece of rod, threading the ends and placing rod ends on it. I just had to measure the length to make sure I could open throttle fully.
dzbowtie is offline   Reply With Quote
Old 09-10-2015, 12:11 PM   #9
mgkgmc
mgkgmc's Avatar
Sounds great I'm learning as I go some what so that would be awesome. Thanks
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
Old 09-10-2015, 02:01 PM   #10
hamjet
hamjet's Avatar
If you still have the stock throttle rod and its too short going from 6 th 8 cyl. you can always lengthen it by cutting it and slipping on a piece of steel brake line, and weld and grind it smooth like I did, or take FirstOwner69 up on his generous offer....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-10-2015, 06:43 PM   #11
frogsmakr
frogsmakr's Avatar
Seems like the perfect time to go to a cable type setup. You have the cable already , just need the gas pedal out of a later truck. It's not that difficult to do.
67 C-10 shortwide
'06 Triumph Thruxton
'09 Harley 'Lectra Glide
'95 Z-71 two door Tahoe
frogsmakr is offline   Reply With Quote
Old 09-10-2015, 07:21 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
1972 (and maybe 1971) had throttle cables from the factory. You could switch to a '72 pedal and cable if you wanted.
Other than that it's a throttle rod that can be bent or adjusted to make it work with almost any setup.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-10-2015, 10:29 PM   #13
mgkgmc
mgkgmc's Avatar
I decided to go with building my own route. So far so good I'm making quick progress. Thanks for everyone for helping out.
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
Old 11-21-2015, 09:13 PM   #14
ccautoupholstery
Could you give some details on the size rod and fittings you used to build this
ccautoupholstery is offline   Reply With Quote
Old 11-22-2015, 12:53 AM   #15
Lattimer
Lattimer's Avatar
I did one for mine with threaded rod and him joints. The rod was 1/4" fine thread and the joints had 1/4" holes and 1/4" female fine threads. I got the helm joints on Ebay and the threaded rod at the local mom and pop hardware store.
If you look close you can see it in the picture.
I just got finished taking it out and putting in a cable and the later style pedal from Lokar.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
