09-10-2015, 12:26 PM | #1 |
Unexplained noise
So my truck has a weird grinding/vibrating noise coming from either right in front and under or directly under the drivers feet. Here's the kicker! It only happens when a heavier driver (I'm 200 lbs) is sitting in the driver seat and moving slowly (reverse or in drive). My lady will slide over to hold the truck still so I can try to find the noise but it disappears. It's been here for a few months or so
09-10-2015, 02:09 PM | #2 |
Re: Unexplained noise
Wheel bearings, possibly.
Paul |
09-11-2015, 01:01 AM | #3 |
Check the body bushings maybe there moving just enough for something to rub or rattle I'm I big guy myself (290 lbs)my truck is lifted I could hear some weird noises when I jump up in it till I installed new bushings
09-11-2015, 01:31 AM | #4 |
Probably a body bushing,Is it 2wd or 4x4?
09-11-2015, 02:08 AM | #5 |
09-11-2015, 02:19 AM | #6 |
Will I have to order the kit of bushings offline? They are pretty pricey
09-11-2015, 03:27 AM | #7 |
I used a set of polyurethane bushings I think they where $100
09-13-2015, 12:46 PM | #8 |
09-13-2015, 01:35 PM | #9 |
I was so long ago I don't remember to be honest with you I've ordered a lot of parts over the years from LMC /JEGS /ORD
