Old 09-10-2015, 02:45 PM   #1
canadian_diesel1964
Removing the engine with a manual trans
Hey guys I was wondering...when you have a manual trans and you want to remove the engine is it just a matter of unbolting the bell housing and the front mounts and pulling the engine with leaving the driveline in place? or is it too much of a pain to align the input shaft later when replacing it...I am new to manual trannies so a question I need to answer before I do my T5 swap. Thanx
canadian_diesel1964 is offline   Reply With Quote
Old 09-10-2015, 04:05 PM   #2
1963c-10
1963c-10's Avatar
Re: Removing the engine with a manual trans
Yep....just unhook everything from the engine. Take the bellhousing to block bolts out and the bellhousing/trans will remain in place. If you plan to swap the trans anyways, you may just consider pulling them at the same time. Some pickers will lift high enough, sometimes you need to let the air out the front tires to give you the extra inch or so. Either way....its easier with the hood removed in my opinion.
As for reinstall...it does make it a little harder to reinstall just the engine only when the trans/bellhousing are in place on a manual. As long as you use the clutch alignment tool to center the clutch disk and an extra set of hands it can be done though.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-10-2015, 05:40 PM   #3
Lugnutz65
Lugnutz65's Avatar
I found that removing the radiator support and other stuff made it very simple. Tranny and engine came out together. Not the only way to do it but I was parting the truck out anyway, so all of it was coming off anyway sooner or later.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-10-2015, 05:43 PM   #4
slorio
slorio's Avatar
I second Lugnutz 65. Here's my picture and previous discussion (see link below). I pulled a 305 V6 and three speed overdrive tranny with cast iron cases in one lift. It was a heavy load, but with the front end removed, I did it by myself with no issues.
Regards,
Steve
http://67-72chevytrucks.com/vboard/s...d.php?t=658269
slorio is offline   Reply With Quote
Old 09-10-2015, 06:44 PM   #5
canadian_diesel1964
I didn't want to get into pulling the motor yet...I'm going ahead with the T5 swap then next fall pull that 283....
Old 09-10-2015, 08:17 PM   #6
Lugnutz65
Lugnutz65's Avatar
OK, reading over the original question in you first post, it sounded like you wanted to pull the engine too.
So now it sounds like you really just want to pull the bell and tranny off the engine. If that's the case, then you will need to support the rear of the engine before you remove the bell.
Here's what I'd do.
Remove the drive shaft.
Remove all the stuff connected to the clutch fork.
Remove the starter.
Remove the speedo cable.
I'd recommend removing the tranny now but you could wait and do the bell and tranny together. I think together is harder.
Remove the 2 bolts that hold the bell to the cross member support.
Jack up the rear of the engine up so the bell is about 1/2 inch off the bell cross member. Don't jack it up more or the fan will hit the radiator.
Support the back corner of the engine block with a jack stand.
Support the tranny somehow (if it's still on the bell) to reduce binding when you try to remove the bolts that hold the bell to the engine block.
Unbolt the bell and tranny as a unit (or separately).
If the cab is still on the frame, you will struggle with the tranny because it's heavy. So have a helper.
I hope I didn't forget anything.
Old 09-10-2015, 08:42 PM   #7
canadian_diesel1964
That's great Jay ...I'm sorry I confused you I was trying to make sure that doing the engine later was a good option...your instructions are perfect!
Old 09-10-2015, 09:28 PM   #8
padresag
you did originally ask about removing the engine.
if you are re & re'ing the trans there is no sense in removing the b/housing. you can drop the clutch out the bottom and the flywheel if required. why make more work for yourself
ron
padresag is offline   Reply With Quote
Old 09-10-2015, 10:22 PM   #9
MikeB
MikeB's Avatar
When I removed the 250 six from my 82, I supported the oil pan with a floor jack and a 2x6, and then pulled the 3-speed trans from the bell housing and wrestled it to the floor. Lifting out the long engine was then a piece of cake.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
