Old 09-10-2015, 08:34 PM   #1
picklito
Just drop spindles?
Can't find pics of front end height on a 67-72 that has stock springs and 2.5" drop spindles. Please post if you have some pics. Thx.
picklito is offline   Reply With Quote
Old 10-10-2015, 10:26 AM   #2
picklito
Re: Just drop spindles?
Nobody is running drop spindles and stock springs?
Old 10-11-2015, 10:56 PM   #3
davischevy
davischevy's Avatar
Here's a 2.5/4 drop with stock springs. I'm thinking about another 2" all around.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 10-13-2015, 02:07 AM   #4
andrewmp6
Just remember if you have factory springs they do sag over the years so it might be a little lower then you plan on.
andrewmp6 is offline   Reply With Quote
Old 10-15-2015, 12:30 AM   #5
68c10airstream
68c10airstream's Avatar
My 68c10 has ece stock small block (no ac) springs with 2 1/2" dropped ece spindles and i tape measured from the center of the wheel UP to the wheel opening and both sides are 15 1/2". Keep in mind tire height has no bearing on this measurement. My ls engine is sitting a little farther back than the small block was and the ls has aluminum heads. Ece warranty claimed the front coils for sagging on one side and he asked for this exact measurement procedure. My replacements are about 4 years old. Also to consider is if you lower the rear end it has a slight tendency to lift the front.
68c10airstream is offline   Reply With Quote
Old 10-15-2015, 12:33 AM   #6
68c10airstream
I should add that my 68 c10 has 4" lower ece springs and 1" lowering blocks in the rear.
Old 10-20-2015, 04:46 PM   #7
picklito
Thanks! Looks like I'm gonna use some stock height 73-87 spindles. Got a good deal on some used ones, and only plan to lower 1-2" anyway.
