Old 09-10-2015, 11:21 PM   #1
cru_zn_29
cru_zn_29's Avatar
GenIV Throttle
I am trying to come up with pedal/ wiring/ module that will work with GenIV 58x system.My 5.3 LY5 from 2008 Avalanche DBW Has anybody done this before?
cru_zn_29 is offline   Reply With Quote
Old 09-11-2015, 12:35 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: GenIV Throttle
I know we talked in PM, but you might want to check out Hart_Rod's build.. I know he was one of the earlier GenIV swaps on the site here.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-11-2015, 01:36 AM   #3
cagodinez
cagodinez's Avatar
Re: GenIV Throttle
The guy that reworked my harness told me I could use a 2008 Impala pedal so I did, I haven't finished my swap but it did plug right in. The Corvette pedal is too pricy for me.
cagodinez is offline   Reply With Quote
Old 09-11-2015, 10:45 AM   #4
dayj1
Re: GenIV Throttle
There isn't an interface module for the pedal in a Gen IV system, so you just need the pedal its self. One of the few things about a Gen IV system that is actually simpler than Gen III is that all the pedals have the same internal sensors. I used a 2007 Monte Carlo SS pedal because it was cheaper than the Corvette pedal and a lot better looking than the giant truck pedal. The Gen IV pedals have a 6 pin plug and two wires need to be swapped in the harness to switch between Gen IV car and truck pedal styles (pins "D" and "F").
dayj1 is offline   Reply With Quote
Old 09-11-2015, 12:23 PM   #5
cru_zn_29
cru_zn_29's Avatar
Re: GenIV Throttle
Thanks for responding. When using the Monty Carlo pedal is there a jumper harness that is needed if so where doe's it go. I am using my OEM harness the only harness connection left is a 24 pin with a latch i have assumed it was for a module.Any help is much appreciated
Old 09-11-2015, 12:43 PM   #6
dayj1
Re: GenIV Throttle
I've only used the harness from a truck application And it has a sub harness for the pedal. It connects to the accelerator pedal and the brake switch (among a few other things) and passes through the firewall where it plugs into the engine harness.
Old 09-11-2015, 12:51 PM   #7
indymachinist
Re: GenIV Throttle
If you are trying to go on the cheap these pedals are starting to show up quite a bit in the junk yards. A Pic-A-Part type yard should have them in there.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-11-2015, 01:45 PM   #8
Mr.chivo
Re: GenIV Throttle
Im using one out of a 2009 van, its a slim good looking pedal but might have to modify the angle of the actual pedal position, it curves a lil too much for my taste.
Mr.chivo is offline   Reply With Quote
Old 09-11-2015, 03:27 PM   #9
cru_zn_29
cru_zn_29's Avatar
Re: GenIV Throttle
So now i am seeing this clearly. I need the sub harness for my truck harness and i don't need the module. Thanks
