09-11-2015, 04:15 PM | #1 |
Door Question
LMC and other suppliers, split the years for doors between 1973-1976 and 1977-1987. Does anyone know what the differences are that require the split years?
I have a lead on a 1977 aftermarket door, for a really good price, that makes fixing a couple of dents in mine more costly than swapping the door. However, my project is a 1974 C20... and I am concerned about the reason the vendors split the years at the 1977 model year. Thanks! Dave UPDATE: I just got off the phone with LMC and they don't know why the years are split at 1976/1977... just that they are different. Suggested I call the manufacturer...
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." Last edited by old Rusty C10; 09-11-2015 at 05:54 PM. |
09-11-2015, 05:53 PM | #2 |
Robert Olson Transport
Re: Door Question
the split as far as I know are 73=80 and 81=87 (91),, the differences are the interior portion to accommodate door panels
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 09-11-2015 at 09:25 PM. |
09-11-2015, 08:27 PM | #3 |
Re: Door Question
The 73-76 use the smaller door panels and the 77 up use the bigger panels. The 73-76 are hard to find not rusted out on the underside.
09-11-2015, 09:26 PM | #4 |
Re: Door Question
there was also a difference in the window cranks ( longer stem) until 1980
09-12-2015, 12:51 AM | #5 |
Re: Door Question
So bottom line is, since this is just a door shell, I can move my components over to the 77 door, maybe have to drill some holes or something for the door panels, but hardware wise (regulator, wing windows, etc...) and external fit wise, it should be fine?
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
09-12-2015, 07:50 AM | #6 |
yeller
Re: Door Question
100% incorrect. Inner door guts are different...only 73-76 parts will work on a 73-76 door...same for 77-87. Inner window tracks are different, window regulators are different...and don't interchange between 73-76 and 77-87 doors. Found out the hard way trying to put 73 parts in a 77+ door.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
09-12-2015, 08:40 AM | #7 |
Re: Door Question
again I disagree I can show you photographs of factory new reproduction doors factory marked 73-80 I too have tried putting 81 up parts into the earlier door ad it wouldn't work as far as windows but the locks are pretty much the same . there were subtle differences like the latch on the wing window and design of the inner door handle I can also post a picture of the 73-80 door shell that ive removed from my 74 it will bolt up and I can and have swapped parts with my 79
09-12-2015, 02:09 PM | #8 | |
Re: Door Question
As for wing windows, if the door opening for the glass is the same shape and angle, then again it comes down to mounting locations or raised bosses for bolts... If the above are reasonably correct assumptions, then I have to assume I would need to get all new guts from stem to stern and install them in the '77 door. Besides bodywork, my passenger door needs a new regulator anyway, and both wing windows need refurbishing... So it all comes down to: will the '77 door profile fit the '74 opening?
09-12-2015, 05:28 PM | #9 |
Re: Door Question
73-76 and 77-91
09-12-2015, 07:55 PM | #10 |
yeller
Re: Door Question
When i went to put my 73 guts in a 77 up door...i had to swap out the inner door roller tracks...they were different. On top of that, the window stalks were too short, and would not work with the 77 up door panels.
09-12-2015, 08:43 PM | #11 | |
Re: Door Question
Ironic how there are certain areas where the '73-'87 really isn't '73-'87 when it comes to interchangeability. Really need at least four sub groups, '73-76, '77-87, '73-'80, '81-87, and God only knows how many more. Seems like a lot of "change for change sake." Adds spice to the hobby.
09-14-2015, 04:05 PM | #12 |
78K & 79C Jimmys
Re: Door Question
I swapped 89/87 Burb parts into 78 doors,
I noticed older doors have thicker glass,this may affect ordering seals. older locks use metal rod clips,newer use plastic. older vents have no locks,newer do,bolted right in. I'm sure i used newer (87)regulators ,in 78 doors.
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
09-15-2015, 04:06 PM | #13 |
Re: Door Question
I always liked those early doors best. Something about showing that much sheetmetal around the panel always says "this is a truck", but I also like the plaid bench seats as well, so my taste can't really be trusted.........to be anything but groovy
jjmorrse 86 C30 crewcab big dooley. 454- 400 |
09-15-2015, 05:04 PM | #14 | |
Re: Door Question
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-15-2015, 05:28 PM | #15 |
Re: Door Question
73 is a 1 year only regulator with the small plastic rollers and the 73 door glass has the smaller channel for those smaller rollers.
09-15-2015, 10:34 PM | #16 |
yeller
Re: Door Question
So are your saying GM made a '73 only door too because of these changes? When I priced out doors from GM back in '95, I had 2 options...73-76, 77-91. One would think the regulators would follow the doors for changes that affect window fitment. Not being a smart ass, just trying to understand the differences/changes.
09-16-2015, 12:14 AM | #17 |
Re: Door Question
I figured you'd have more info on this debate.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
