Active Member
![]() Join Date: Mar 2004
K30 front brake line brackets
Did these front brake line brackets only come on K30's? My truck is an '83 K30 and they're junk from a previous owners poor decisions. I'm trying to figure out where I'm going to find some replacements since I'm getting ready to go through the entire brake system, supspension, and axles.
The picture on top is what they're supposed to look like, the picture on the bottom is what I'm currently stuck with. ![]() ![]() |
Re: K30 front brake line brackets
Not sure what those are for. Not factory, I do know that
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
Active Member
The big hunk of booger welded on steel on my truck isn't factory but the one in the top picture is. You can tell since it's riveted on, I'm just not sure if they started on 81+ trucks, or if they were only on K30's 81+ or what they came on. I would just go to a junk yard and start looking at trucks but there aren't many around here anymore that let you just wander around.
#4 | |
I don't know for sure if the K10 / K20 brackets are the same as the ones used on K30's though. |
