Old 09-12-2015, 01:21 AM   #1
Chrispbrown36
Camber adjustment ?
So after putting new tie rod ends on I took it to a tire place up the road from me to get an alignment done. I have used them a fair amount of times since they are so close and they have always been straight forward with me. Today on my lunch break I called to see if they got it done and the owner wanted to talk to me. He told me that the camber needed to be adjusted but "those trucks weren't designed to have the camber adjusted." Not having any knowledge of camber, I pressed for causes, parts that might need to be replaced, etc. He told me over the phone that nothing can be done. When I went to pick it up I talked to him again and when I pressed it he mentioned shims, but said that it would be a BIG job if it even made a difference. I found this all hard to believe.
He gave me the print out on the alignment and it lists camber on the left at positive .4 and the right at negative .6. He said he didn't think that it would cause any major issues, but "I wouldn't even mess with it if I were you." So what do you guys think? Please feel free to educate me on camber and how to correct it.
Chrispbrown36 is offline   Reply With Quote
Old 09-12-2015, 01:40 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Camber adjustment ?
2WD is fairly easy to adjust Caber and Caster using shims on the upper control arm.
A lot of outfits have gotten used to the modern rigs that are not adjustable and don't like to do the whole job on older rigs that are.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-12-2015, 09:34 AM   #3
Chrispbrown36
Sorry, I forgot to mention.....It is a 87 4x4.
Old 09-12-2015, 09:15 PM   #4
v30crewcab
v30crewcab's Avatar
pretty sure they make a shim that bolts behind the spindle.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-12-2015, 09:33 PM   #5
cadillac_al
They do but it usually isn't worth messing with it for a 1/2 degree or so. Mine was off a little but I figured it lasted almost 40 years the way it is and the tires wear dead even so I don't worry about it. If it was off a few degrees and it looked like it might wear the tires then you go through the big job of putting a shim behind the spindle. It sounds like yours would be close enough for me.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 09-12-2015, 10:30 PM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
My right side was leaning in by 1 degree at the top. I installed a shim I ordered from these guys and got my alignment done.
http://www.ingallseng.com/26126-6-bo...mber-shim.html
Installation Instructions
1. Determine the degree of change needed to correct alignment. 2. Disassemble front wheel, hub, brake assembly and backing plate. Mark the top of the spindle to avoid camber changes during reassembly due to a slightly bent spindle. Remove the spindle from the steering knuckle. Clean all surfaces thoroughly. 3. Locate the notch of the shim for the proper degree of change needed. Place that notch at twelve (12) O'clock for positive camber and at six (6) O'clock for negative camber. 4. Reassemble the brake assembly, hub and wheel and adjust toe to specifications. Important Notes: The webs of the shim between the bolt slots will occasionally interfere with the steering knuckle bolt heads or studs, preventing the desired notch from being set at exactly twelve or six O'clock. When this occurs you need to simply flip the plate in the following manner. 1. Position the camber plate against the spindle with the desired notch for proper alignment at twelve or six. 2. Mark the location of the 1-1/2° notch on the outside edge of the spindle. 3. Flip the camber plate over on its back, keeping the 1-1/2° notch lined up with the mark on spindle. Although the desired alignment notch will no longer be at the original twelve or six O'clock position, the proper camber adjustment will remain the same. Due to the thickness of the shim, longer spindle mounting bolts may be required for reassembly. If so use 3/8"x1-1/2" grade eight bolts. If necessary, grind off bolts for hub clearance.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-12-2015, 10:41 PM   #7
Chrispbrown36
As of right now I am not too worried about it.....the camber isn't too bad. But the plan is to get it back to factory condition so somewhere down the road I might mess around with it.
I have seen the shims but I have also seen the camber adjustment sleeves....anyone know anything about them?
