09-12-2015, 09:41 AM | #1 |
Steering problems
1986 k10 brand new 4" lift.
When making left turn Truck will suddenly jerk to the right and steering will get sloppy. Doesn't happen every time. Checked rag joint and all steering components all look good. Bad steering box? Power steering pump is a bit overfilled. Not sure what else to look for. Lift was installed before I bought truck so not sure if these symptoms were there before. Has the 4" raised steering arm. Is it possible I need to change the drag link also ? Any help would be appreciated. |
09-12-2015, 07:05 PM | #2 |
Re: Steering problems
Frame cracked?
09-13-2015, 03:23 PM | #3 |
Frame is good no cracks.
09-13-2015, 03:55 PM | #4 |
Perhaps the valve in the box is gacked out? Did it make noise or just feel like you suddenly steered right while :-/ the middle of a left turn?
09-13-2015, 08:02 PM | #5 |
No noise. Not sure what valve your referring to ?
09-13-2015, 10:45 PM | #6 |
There is a valve on the steering shaft that directs pressure to the appropriate side of the ball screw piston depending on direction of shaft rotation. It may have an issue. I've never heard of that, but who knows.
09-13-2015, 11:03 PM | #7 |
perhaps your being yanked from the rear and mistaking it for a steering component issue; when your issue is actually the rear no-slip or limited-slip mechanics!
White K20 |
09-14-2015, 06:47 AM | #8 |
Just dropped the tranny to do rear main seal. Should have it back together by weekend. Will look into all of that. Steering fluid looks real dark red. Isn't it usually more of a clear fluid ?
09-23-2015, 11:19 AM | #9 |
Just had the same type of issue with my 86 k30
when cold or after making a sharp turn the steering wheel will jerk left or right. Scary! Then go away. I did everything. Then I checked the front dana60 ujoints. WASTED. They were fighting each other. Rise the front and lock the hubs IIRC, rotate the wheels by hand.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
09-23-2015, 12:15 PM | #10 |
Red fluid is just that someone put atf in the system instead of power steering fluid. Both are hydraulic fluids and have similarities. Not a big deal really.
09-23-2015, 07:51 PM | #11 |
Back in the "old days" they were the same thing
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
09-29-2015, 08:39 AM | #12 |
Yes but this stuff is thick dark burnt red. going to replace fluid.
Measured the steering arm on my 73. Definitely has more rise than one on the K10. Purchased new 4" lift steering arm. Had 1" aprox. more rise than the one that was on there. Steering arm that was on there was definitely not original but I didn't think they made a raised steering arm for anything less than 4" lift so not sure. Axle also has some play in it on both sides. Going to replace all the wheel bearings on both sides but the new arm seems to have done the trick. truck is turning fine now. Thanks guys. |
10-01-2015, 12:50 AM | #13 |
Check what the others have suggested, but I can say I had the exact same issue with my '87 V20 and it was the result of a bad steering box.
Changed the box and 2 years later no issues. |
10-03-2015, 07:48 AM | #14 |
The axle u-joints will only affect steering (or anything) when front axle is engaged in 4wd. People put ATF in leaky steering boxes, so that's a sign your box is crapped out. I wonder if the steering arm that was on it was for another application than GM. That inch difference is not enough to throw things off much at all.
10-03-2015, 07:08 PM | #15 |
Truck has been fine since I changed the steering arm. No steering problems at all. I would have to assume that made the difference. Just happy it's all good.
