09-12-2015, 12:55 PM | #1 |
Bed mounting
I should have the bed back on Sunday and will need to start with the layout of the strips. I've check several threads and am not quite finding a lot of info. Any pointers will helps. I've got the mar-K sheets but am a bit lost as usual. I have the 8' fleet side model.
do the cross rails get mounted to the truck frame first them you set the bed on them and then install the wood? Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
09-12-2015, 02:19 PM | #2 |
Moderator
Re: Bed mounting
I don't think the Mar-K instructions say to do it that way:
https://app.box.com/s/n3qahmyqzpkxk763z996taefyyaa448m
09-12-2015, 02:27 PM | #3 |
Moderator
Re: Bed mounting
I did it completely off the frame, then put the bed back on, and finished the last couple of boards/strips. I left the middle ones out to put a strap around so I could lift with a strap and my engine hoist.
If you can, do the assembly off the frame. Doing all those bolts is a pain, having the frame/axle/suspension/exhaust in the way will make it much worse. |
09-12-2015, 03:30 PM | #4 |
Re: Bed mounting
I layed mine out vey similar, but had the bed resting on the frame. Started with the outermost and worked in. It definitely took two people, to manipulate / massage the boards and strips into place. Just did he bolts snug initially, and once it was all together I flipped the bed up on end and tightened everything down.
09-12-2015, 04:10 PM | #5 |
Re: Bed mounting
Jay.
I like how you did it, so you attach the bed rails before mounting to the frame
