09-12-2015, 04:36 PM | #1 |
What is this spring doing on the brake hubs?
Previously ignored them, but my front hubs (possibly the rears too) have these springs wound around them.
Any idea why they are there, and can I remove them without expecting a blow up? I want to remove them as they seem to serve no purpose, so that I can clean up and paint the hubs. Thanks again as always for your help.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
09-12-2015, 04:43 PM | #2 |
Re: What is this spring doing on the brake hubs?
Most believe that they prevent a humming/ringing noise. Others say they help dissipate heat. Maybe they do both things. I have heard they are a real bugger to get put back on.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-12-2015, 07:23 PM | #3 |
Anti-chatter/squeal/vibration? A humming/ringing noise as 71swb suggested could drive you nuts when braking! Rubber straps wrapped around them when turning a drum are for anti-chatter--makes a heck of a difference in smoothness of the turned surface when finished.
If you can do your painting w/o removing, I'd suggest keeping them. Also, measure how much "meat" you have left before max. diam. will be reached--could be time for new. No use for pretty if not safe. Sam Last edited by luvbowties; 09-12-2015 at 07:26 PM. Reason: add info |
09-12-2015, 07:53 PM | #4 |
My curiosity made me Google this myself. Here's a good discussion on another forum. Do note the "harmonics" section(s):
>> http://www.chevytalk.org/fusionbb/sh...hp?tid/311468/ << Sam |
09-12-2015, 08:00 PM | #5 |
As my screen name suggests, I am a machinist. Let me tell you, it is AMAZING the difference something like a rubber strap or even a basic rubber band can make to break harmonics when you are turning a part. I would have to agree that is exactly what that spring is there for. GM must have realized there was a resonance in the drum and added the springs to get rid of it.
Edit: Just read a bit of that thread posted above me. The spring is absolutely not there to keep the drum concentric. I am highly skeptical it aids in any noticeable fashion to heat transfer either. |
09-13-2015, 12:08 AM | #6 | |
Keeping in mind that the biggest engineering skill I possess is making a cuppa tea...... We noticed yesterday that the drums that came off my truck, were noticeably lighter than those spare ones I got from Ian. As was their design as well. My drums are smooth, no ringing, and used to work real well. I guess someone who knows, will just pick them up and say..... "End of the line" but how do I check?
09-13-2015, 12:19 PM | #7 | |
Sam |
09-14-2015, 12:19 PM | #8 |
55-56 chevy cars came with springs like those. early tk's probably had them also--maybe the design of later drums are different?
1961 chevy K10 my build is------------61K10 build |
09-14-2015, 01:14 PM | #9 | |
My screen name doesn't suggest it but my signature does: I was a brake development engineer for GM Light Duty truck at the Desert Proving Ground, specializing in Noise and Vibration work. The text below is from a previous thread -
The spring is absolutely positively not an aide in heat transfer or to keep the drum concentric. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-14-2015, 03:40 PM | #10 |
Keith !!! You hero.
Thank you for the reply.
09-14-2015, 10:12 PM | #11 |
You learn something new every day! Very interesting discussion.
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
