Old 09-13-2015, 11:14 AM   #1
dkauffman05
dkauffman05's Avatar
hunting a mirror help
I'm having trouble finding a mirror to fit my truck. I probably should have done this research before I painted the truck but I'm wanting some that use these holes or I can drill new holes as long as the new base will cover these . I would like a round mirror preferably black or paintable. This is the best picture I have of the holes
dkauffman05 is offline   Reply With Quote
Old 09-14-2015, 06:17 AM   #2
merlin3
Re: hunting a mirror help
i just got mine from summit,huge selection you could call the summit tec line for measurements .
merlin3 is offline   Reply With Quote
Old 09-14-2015, 10:33 AM   #3
mike16
if you see mirrors among cars, and you like it check the dealers or if its too pricey check availability through rockauto. I went to Toyota to buy '90 Camrry power rear view door mirrors and they wanted almost 400 each. Rock auto...70 dollars each
mike16 is offline   Reply With Quote
Old 09-14-2015, 11:36 AM   #4
michael bustamante
michael bustamante's Avatar
wouldnty those be the 72 sport mirrors?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-14-2015, 01:20 PM   #5
dkauffman05
I belive you're right on the 72 sport mirrors, but there a square mirror and my truck is going to have a 70 grill . The doors might me 72 .
Old 09-14-2015, 02:29 PM   #6
GMCPaul
The 2 holes in your door are not from stock 67-69 Chevy or GMC truck mirrors, nor are they for stock 70-72 deluxe truck mirrors. So if you plan on using or covering those holes you'll need to get a different mirror than stock.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 09-14-2015, 02:30 PM   #7
notsolo
notsolo's Avatar
The 72 sport mirrors have 3 mounting holes and are mounted forward of your holes and down an inch or more on the 2" flat strip.
notsolo is offline   Reply With Quote
Old 09-14-2015, 02:37 PM   #8
dkauffman05
So most likely someone drilled those holes in my doors ?
Old 09-14-2015, 02:46 PM   #9
GMCPaul
Yes someone drilled those holes for a mirror that was not stock.
The stock single arm 67-69 mirrors also use 3 holes on the flat area below and slightly forward of where those are located. To my knowledge those holes do not match the location for the stock Jr West Coast or west Coast mirrors, not the other optional mirror package available in 67-72.
Paul Jr. @ GMCPauls
Old 09-14-2015, 03:04 PM   #10
michael bustamante
is there a threaded plate mounted to the backside of the door skin where the holes are?
1967custom
Old 09-14-2015, 03:35 PM   #11
dkauffman05
No threaded plate. Think I'm gonna try and find a comaro or chevelle mirror that will atlest cover my holes if I have to make new ones.
Old 09-14-2015, 03:44 PM   #12
john
member #16
john's Avatar
These are what I have on my truck. They will fit your existing holes.
http://www.lmctruck.com/features/cc/CCMR1.htm
john is offline   Reply With Quote
