09-13-2015, 09:24 PM | #1 |
6.2 swap in my 67 c10
So I found a 2013 6.2 escalade engine and transmission I was wondering will I have to do any modifications to get the 6 speed transmission to fit in my truck also what would be the easiest way to wire this up to my I have practically zero knowledge when it comes to wiring anything up any help would be greatly appreciated
09-13-2015, 11:35 PM | #2 |
Re: 6.2 swap in my 67 c10
You don't want that...
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
09-14-2015, 06:08 AM | #3 |
Whys that?
09-14-2015, 07:04 AM | #4 |
Your gonna need at least a high hump for that trans. Jim
09-14-2015, 07:40 AM | #5 |
Ok thanks very much
09-14-2015, 08:50 AM | #6 |
There are several company's that build swap harnesses for all sorts of LS Engines. some are on the Cheap some get real expensive. there are guys that offer rework services on eBay as well.
Personally I would run a Holley LS engine computer, they have come our with a new setup that has pre programmed tunes that will get you started and you wont have to get your factory computer re tuned to disable the anti theft and other things such as emissions.... I am thinking Holley will not support the 6 speed though???? |
09-14-2015, 08:54 AM | #7 |
Sounds like I won't be able to put the 6 speed in my truck I wonder if a 4l80e will bolt up to a 6.2?
09-14-2015, 09:29 AM | #8 |
I would fab up a high hump if needed. Those 6 speeds are some good transmissions. Talk about gearing and some great milage in these light trucks
Current: 2012 Ford F-250 4x4 6.7 Powerstroke 1971 C-20 2wd 350/TH400 Former: 1979 C-20 2wd 350/TH400, 300+hp. Rattle can paint job 1982 K-30 454/700R4. 4in lift with 37" Goodyear MT/R's Lots of goodies - Trail clean up truck |
09-14-2015, 09:32 AM | #9 |
Sounds like a great swap to me. I would stay factory harness and computer and run the 6-speed. You may have to do some fabrication, but that will be a killer combo!
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
09-14-2015, 10:37 AM | #10 |
Yes the 4L80 will bolt up to a 6.2L in which case you can use the Holley stuff.
Size wise I am still not sure you would get away without using the High hump or modding the floor. The 6 speeds are great transmissions but they are Huge. If you can get it in the truck it would work great on a factory style harness and a good tune. |
09-14-2015, 10:45 AM | #11 |
1965 Chevy C10, 2005 4.8L/4l60
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
