09-13-2015, 11:13 PM | #1 |
Need 6 lug Wheels!!!!!
I need a set of 6 lug wheels with center cap clips for a 58 Apache. 15"
I can sandblast and paint em...... |
09-13-2015, 11:38 PM | #2 |
Re: Need 6 lug Wheels!!!!!
I had a few I think 60s/70 16.5 6 lug with center clips
09-13-2015, 11:51 PM | #3 |
I think 58's either came wirh a 15X5 or 15X6 and could also be ordered with a 16X6.
I'd really like a set of 15/s.......... |
09-14-2015, 06:26 PM | #4 |
I've seen on other sites of guys using wheels from here
http://www.dexstarwheel.com/products.pdf They're trailer wheels, but more than up to the task You can get hubcap clips from a vendor and install them on your wheel http://www.laroke.com/larryk4674/smo...er/hubcaps.htm http://www.brotherstrucks.com/prodin...number=HCRC066 |
09-14-2015, 09:44 PM | #5 |
You sure this'll work?
I'm ready to give it a try...... |
09-14-2015, 11:17 PM | #6 |
I have a set of 4 15in 6 lug chrome,chrome is in bad condition needs to be redone or painted somebody put them on a early 70s chevy luv I had, they don't have clips ??
09-14-2015, 11:36 PM | #7 |
$50 a piece.
I don't think you could sandblast and paint an old rim for that. Looks like they have a 3" backspace. Should clear your tie rod ends just fine. http://www.etrailer.com/Tires-and-Wh...r/AM20514.html |
09-14-2015, 11:53 PM | #8 |
your not looking for the split rim ring type are you??
09-15-2015, 12:01 AM | #9 |
Looking for something as close as I can get to OEM, if I can't get OEM.
GM musta made 6 billion of these things, but none seem to be popping up. I don't think a 3" backspace is gonna work - what was OE? 4" I suspect, but not certain...... |
09-15-2015, 05:13 PM | #10 |
3" backspace would be just fine.
The OE wheels were somewhere between 3.5 and 3.75. Anymore than that and you get dangerously close to interfering with your tie rod ends. |
09-15-2015, 05:49 PM | #11 |
Moderator
09-15-2015, 09:43 PM | #12 |
JAY - I ordered the "Trailer Rims" last nite, but who knows if that little experiment is going to work out.
How much do you want for your rims shipped to 53821? I don't need the tires. Dog - I think the backspace will be OK on the trailer rims - might be close. Website says its just under 3.75" |
09-15-2015, 09:49 PM | #13 |
Jay - I just noticed you're in Ontario. Probably gonna be too much $$$$$ to ship from Canada?????
I dig the RMW's. I have 2................ |
