Old 09-14-2015, 11:02 AM   #1
dave`12
dave`12's Avatar
1967 c10 drop opinions please
1967 c10, 1/2 ton fleetside, I6. The suspension is in good shape, only has worn shocks. Coil springs all around, it does have the one leaf option on the back for heavy loads.
So, I would like to lower it on the cheap. Not looking to go super low, just bring it down a couple of inches or so for looks. Years ago, I lowered the front of my 1969 firebird by taking a hacksaw to the coil springs, but ended up going lower than I liked.
Does anyone know how to determine how much I should cut off the springs for 1 inch and for 2 inches? The springs look pretty good, I'm guessing no sag right now, so no need to account for that (I hope).
I know the advice will probably be to buy lowering springs, but my budget can't afford that and still allow me to do the other things I need to do.
Pictures of trucks lowered 1 and 2 inches would be awesome to let me know how much that change would actually be!
Thanx in advance
Here is a pic with a truck about as low as I'm looking to go:
dave`12 is offline   Reply With Quote
Old 09-14-2015, 12:01 PM   #2
dave`12
dave`12's Avatar
Red face Re: 1967 c10 drop opinions please
Ok, so digging around I can already see that, unlike my car, 1-2 inches is not gonna cut it. Please ignore that and go by the picture (anyone have any idea about how much the picture is likely lowered?).
Old 09-14-2015, 12:59 PM   #3
indymachinist
3 and 5? just a guess. def. no more than 3 and 5.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 09-15-2015, 02:54 PM   #4
dave`12
dave`12's Avatar
thanx, curt
any idea how much coil I would have to cut to get to 3 front, 5 rear?
Old 09-15-2015, 09:50 PM   #5
hotrodsinner
hotrodsinner's Avatar
Coil in rear with one leaf? I've never seen that? Was that an option? Can I see a pic of that? I'm trying to wrap my head around it?
hotrodsinner is offline   Reply With Quote
Old 09-15-2015, 09:52 PM   #6
hotrodsinner
Each cool is approximately two inches. So cut 1.5 coil in front. And rear, if it is coils, get a 4 inch drop coil and a one inch drop block. Or 5 inch drop spring. Or a jeep rear coil will give you close to 5 inches.
Old 09-15-2015, 10:02 PM   #7
Slow Build
Slow Build's Avatar
Are you sure that truck is dropped? Looks like it has tall tires that fill the well but it doesn't look lowered to me.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 09-15-2015, 10:30 PM   #8
hotrodsinner
Do not cut the rear coils! I know people have done it, and someone might suggest it. But don't do it. Either buy a drop spring or use a jeep coil.
Old 09-15-2015, 10:34 PM   #9
Robznob11
Robznob11's Avatar
X2! It needs to be dropped and it would look tight!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-16-2015, 09:42 PM   #10
dave`12
dave`12's Avatar
Ok, I know nothing about these trucks, just got it. So this is what it looks like. Coils in the back, now look and you will see one spring. My guess it's for heavy loads. It would probably get in the way of a drop...
It's dark and been raining, so the pic is not that good. The exhaust is in front of where the leaf stops. It does not connect, but would hit a bump when the suspension is loaded.
I never had any problem with the firebird after I cut the coils, I just thought it was a bit too low. I've looked around, I think I want a 2" front and 4" rear drop.
@hotrodsinner: So 1 and 1/2 coils in the front. Please tell me why I can't cut the rear? And which jeep spring? For a 4" drop? If you all think it would be dangerous, I would buy the rear. Don't see why I would use a drop block if that would only get me an inch, better to just buy 4" coil drop, I think.
Old 09-17-2015, 07:29 AM   #11
panhandler62
Java Mechanic
panhandler62's Avatar
That's a "helper spring". My C-20 had those. I didn't know they were offered on 1/2 tons also.
It's supposed to help prevent bottoming out with heavy loads.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 09-17-2015, 11:18 AM   #12
dec010974
dec010974's Avatar
Hello dave`12. are you new to the truck south Florida scene? You have a nice clean C10. I like it a lot. I have never seen this/your truck in Miami. I have a friend, that has a 4-6 drop with rally tires, that's local in South Florida. ill post pics of his truck when I get a chance. good luck an nice truck.
dec010974 is offline   Reply With Quote
Old 09-17-2015, 01:37 PM   #13
michael bustamante
michael bustamante's Avatar
you cannot cut the rear springs. you could add a lowering block though and theyre pretty inexpensive. 2" to start. as for the front spring, just cut 1 full coil off. if its not enoughyou can just pull it and cut another coil but i wouldnt do anymore than that.
and you can leave the add a leaf in the truck. its not hurting anything
1967custom
michael bustamante is offline   Reply With Quote
Old 09-17-2015, 08:22 PM   #14
zipper
Anybody know what wheels those are?
zipper is offline   Reply With Quote
