Old 09-14-2015, 02:13 PM   #1
UKNOWME
UKNOWME's Avatar
4L60E Conversion
I'm having shifting issues with my 700R4 transmission. Since I plan to do an LS swap in the near future I'm considering 4L60E transmission now. I can get the stand alone harness/computer but what else will I need? Does it bolt up? Someone told me I may need to use the 700R4 torque converter. Any specific year work better? Knowledgable input would be greatly appreciated.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-14-2015, 07:49 PM   #2
bilfman
bilfman's Avatar
Re: 4L60E Conversion
I have a TCI-EZ TCU controller, has worked flawlessly for years. All you need is a throttle position sensor and hook up the supplied rpm module to get it up and running. If you go LS then you just hook into the factory LS harness. I have a complete build on here with my install. You will use the 4L60 converter.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 09-14-2015, 08:54 PM   #3
UKNOWME
UKNOWME's Avatar
Interesting, thank you!
1964 Chevy c10
Old 09-15-2015, 05:59 AM   #4
andrewmp6
I would talk to tci or a trans company see what they say will work and won't.
andrewmp6 is offline   Reply With Quote
Old 09-17-2015, 08:22 AM   #5
Desert1957
Desert1957's Avatar
A 700R4 is a 4L60 and was used from 82 to 93 then they went to a 4L60E which is an electric shift 700R4.
The 700-R4 will have a 4 pin electrical connector and a TV cable.
The 4L60E will have a multi-pin electrical connector (13 pins maybe?, not sure) and no TV cable.
Desert1957 is offline   Reply With Quote
Old 09-18-2015, 10:49 PM   #6
gmachinz
If you want a 2WD 4L60E look for an F-Body (93-97 Camaro/Firebird), a B-Body (1994-97 Caprice/Roadmaster wagon) or a full size 2WD truck (1993-97) and make sure it has a "K" in the bell housing casing on the drivers side-it designates a HD version and that's the one you want to build. With a good improver kit like TransGo, extra 1-2 and 2-3 clutches and a 32 element HD sprag, you can build one to easily handle up to 800 HP.
gmachinz is offline   Reply With Quote
Old 09-18-2015, 11:39 PM   #7
UKNOWME
UKNOWME's Avatar
So an 02 Silverado tranny wouldn't work?
Just asking for reference. That's probably the combo I would use if getting engine and trans at the same time.
1964 Chevy c10
Old 09-19-2015, 02:46 AM   #8
andrewmp6
Honestly if you can pull your trans i would have it rebuild and put it back in yourself.Most trans shops if you drop off a trans and pick it up its 500 bucks or so.If you try using the ls trans on a small block your gonna spend close to that in parts like a torque convertor and other stuff to pretty much throw away when you swap in the ls.And with a fresh rebuilt 700r4 you can sell it once you swap in your ls and get a few bucks back.
Old 09-19-2015, 09:28 AM   #9
UKNOWME
UKNOWME's Avatar
That's good advice. Never thought about it that way. To be honest it may have something to do with the kickdown linkage too. 2 people tried messing with it and have been unsuccessful. The truck had a TH350 and I swapped in the 700r4. It has a very long shift and will not shift into OD at times.
1964 Chevy c10
Old 09-19-2015, 10:23 AM   #10
andrewmp6
Yeah if the kick down isn't right it will shift funny.See if you can fix it so you can still drive it tell your ready for the ls swap.
Old 09-19-2015, 11:42 AM   #11
gmachinz
To adjust the TV (throttle valve) cable on a 700R4, you must have full unimpeded pedal travel, and using the correct bracket for your carb, rachtet the cable so it fully seats and push the ratchet release lever down. Then using only your foot feed pedal, slowly depress the pedal all the way to the floor-this automatically adjusts your cable.
Old 09-19-2015, 11:57 AM   #12
UKNOWME
UKNOWME's Avatar
We did that, twice
1964 Chevy c10
Old 09-19-2015, 02:41 PM   #13
RUN GMC
RUN GMC's Avatar
had the same problem with 700r4 in my 86 Buick Regal build(406 sbc, 700r4, 2500 stall, 3.73 rearend)....that trans lasted 4 years and drove it on 3 Power Tours after the 3rd one it started have adjustment issues and I finally lost 3rd gear......so to find a better way to adjust and operate the kickdown I bought this........http://www.tciauto.com/tc/tcir-tv-ca...ml/.......what I had was this..........
http://www.autozone.com/1/products/4....html......the tci was suggested by some fellow cars guys in my area as specifically made for my carb set up over the generic bracket that I had installed.....im fixing to have that 700r4 rebuilt to re-install into my Regal.......its been on the back burner since I started concentrating on my 87 GMC build........
RUN GMC is offline   Reply With Quote
Old 09-21-2015, 07:49 PM   #14
turbosix
turbosix's Avatar
I believe the carb be might the problem. Years ago I had a 700R4 and put a Holley carb on and hooked up the TV cable. It wouldn't shift right no matter how much I adjusted the TV cable. Put the Qjet back on and it shifted fine. I believe it has something to do with the radius.
Tommy
1 Pt. 3:21
'72 C10 LWB 402
turbosix is offline   Reply With Quote
Old 09-21-2015, 10:16 PM   #15
UKNOWME
UKNOWME's Avatar
You don't think it had anything to do with the TV cable bracket?
1964 Chevy c10
Old 09-21-2015, 11:25 PM   #16
turbosix
turbosix's Avatar
Not the bracket that holds the cable steady. Where it hooks to the carb and the geometry it makes is very important. Maybe this will help.
http://www.cpttransmission.com/tech_tvcable.htm
http://purplesagetradingpost.com/sum...o/700R4p1.html
Tommy
1 Pt. 3:21
'72 C10 LWB 402
Old 09-22-2015, 06:17 PM   #17
Tom
driving is in my blood
Tom's Avatar
What's wrong with 98's?!?!?!?!?
What TV cable bracket was used and what carb? I went threw this with my 200-4R as well.
Old 09-24-2015, 08:13 PM   #18
1984 swb chevy
1984 swb chevy's Avatar
I have a 700R4 in my truck. I got rid of the computer and went with a standard HEI and Edelbrock carb. What do I need to do to hook up the trans so the converter will go into lockup?
2010 Tahoe
1984 C10
2005 Harley FLH
1941 Willys Pickup (will never get it done) not for sale
1984 swb chevy is offline   Reply With Quote
