Old 09-11-2003, 02:42 PM   #1
Bowtiefreak
Bowtiefreak's Avatar
I got ?'s on late model beds on our trucks
How much work is there to putting one of these on a truck?Is the rear bumber in the same location as our stock style bumbers? The reason I ask is, I have a early classic hidden hitch and I wonder how that will come in to play. Will I still be able to use it.
I found a complete cherry box for $600 and I am really liking how some of these guys are making them look.
Thanks for any input.
Bowtiefreak
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 09-11-2003, 03:07 PM   #2
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
REAL EASY, And that is a smokin deal.
Got mine for $800 and had to do some glass repair
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 09-11-2003, 03:25 PM   #3
Bowtiefreak
NSANE68-
You got any pictures of your truck. Sounds really nice. What about the fuel door. Did you put the fuel tank in between the framerails and use the door that is there.
Old 09-11-2003, 04:02 PM   #4
jay6891
Car Knocker
jay6891's Avatar
You can use a hidden hitch, I did. I do believe that I had to move it forward more than a stock bed. A blazer tank will fit between the frame rail also with the hitch. I don't think that you can use the stock filler hole on the newer bed because it is in front of the tire. Would take a LOOONG hose to reach. Plus blown rear tire might be bad.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 09-11-2003, 06:45 PM   #5
dinnut
dinnut's Avatar
1
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 09-11-2003, 06:46 PM   #6
dinnut
dinnut's Avatar
2
70 longbed
496/th400/Ford 9"
Old 09-11-2003, 06:47 PM   #7
dinnut
dinnut's Avatar
3
70 longbed
496/th400/Ford 9"
Old 09-11-2003, 06:48 PM   #8
dinnut
dinnut's Avatar
4
70 longbed
496/th400/Ford 9"
Old 09-11-2003, 06:49 PM   #9
dinnut
dinnut's Avatar
5
70 longbed
496/th400/Ford 9"
Old 09-11-2003, 06:49 PM   #10
dinnut
dinnut's Avatar
6
70 longbed
496/th400/Ford 9"
Old 09-11-2003, 06:53 PM   #11
72gmcshorty
72gmcshorty's Avatar
here's mine
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 09-11-2003, 06:53 PM   #12
72gmcshorty
and
1992 Gmc 2wd
Old 09-11-2003, 10:08 PM   #13
mcmlxix
Collector of Projects
mcmlxix's Avatar
there are two on ebay. on in Chicago area and one in Fl.
88-98 Step Bed in IL
the one in FL ended but might still be available
88-98 Step Bed in Bradenton, FL
i wish they were near me !!
Rich
1972 K5 Blazer CST Click HERE
