Old member
Ok most of you know I had the 6.0 installed over a year ago and it's working just fine. I have had some radiator leaks of late and ordered me a new 3 row CHR radiator off E-bay with trans cooler.
http://www.ebay.com/itm/281405991455...%3AMEBIDX%3AIT I will be swapping my electric fans over to the new unit and will be wiring up the new fans with a product I have used on many of golf carts to activate them. This is a simailer product but only 12 volts instead of 36,48 are 72 volts as in my carts. This will be a 12 volt coil with a 200 amp draw for the fans to run off of. I'll have the relays in the system also. It's not much bigger than a stock one but way more powerful. If you interested in this product I posted the link to order them. Oh they can be used as a starter solenoid as well if you have that kind of problem to! ![]() ![]() http://www.cloudelectric.com/product...j-12v-200a.htm
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
