Neighborhood Pickle Slinger
Lower Control Arm - Shaft length
Hi everybody, havenīt been here for a while.
I am putting new Lower A-Arm shafts in and the ones I got are a little different than the ones I have right now. The overall length is fine, it is the inside size that is different. The guy sais it will work just fine where I bought them but I wanted a couple more opinions before I try to put them in. Check out the pictures and you will see what I mean. Can I use them like they are? Thanks Sean
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
Re: Lower Control Arm - Shaft length
Since the locating indents and overall length is the same it will center and install correctly, you will be just fine.
I hope I will be just fine and thanks for the answer.
