Old 09-16-2015, 01:30 PM   #1
no1udknow
no1udknow's Avatar
ok... who is the 60-61 guru?
I have a buddy who bought a 61 with a I6and a sm460, it came with a supposed built 305 and he wants to swap it, as well as install a 700r4. I am familiarwith the newer frames (63-72) but how do you go about ffittingg a 700r4 in that x frame? And will a square body cross member bolt in like it does on a 67-72 for disk brake upgrade?
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 09-16-2015, 04:06 PM   #2
DakotaKid
Re: ok... who is the 60-61 guru?
The crossmember will bolt in just Fine. As far as the 700r, i think it should be fine but i have not done it myself. would require a custom Tranny crossmember and a High Hump floor for sure.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
Old 09-16-2015, 05:00 PM   #3
verdell
verdell's Avatar
Thumbs up Re: ok... who is the 60-61 guru?
The 700r4 fits in but will require a modified cross member. If you have access to a lift and another set of hands, it should be no problem especially if you're removing the torsion bar front end. My brother and I installed mine in the drive way about 3 or 4 years ago. A lift would've been a lot easier...
verdell is offline   Reply With Quote
Old 09-17-2015, 01:54 PM   #4
robber grin
62 C10 frame is the same
Here's mine with 283/TH350 on 72 stands and homemade crossmember
I think it should work.
Good luck ~ rg
robber grin is offline   Reply With Quote
Old 09-17-2015, 02:02 PM   #5
blown240
blown240's Avatar
I have a 350/700r4 in my 61. The low hump clears fine, but the PO put in a different trans mount/cross member
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 09-17-2015, 02:53 PM   #6
padresag
if you look in the FAQ section, it is all there, but I realize that it is easier for someone to tell you
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
ron
padresag is offline   Reply With Quote
Old 09-21-2015, 01:38 AM   #7
no1udknow
no1udknow's Avatar
ron
Sorry Ron, I used the thread search tool, but seemed to get vague results, guess I shoulda checked the FAQ
Built not bought!
Old 09-21-2015, 10:36 AM   #8
doobiebro
doobiebro's Avatar
Bought me a universal tubular engine mount and trans mount and cut, fabbed it to fit. Powder coated and it came out nice. Sorry no pics on the engine mounts but I shorten them and made them like pedestals witch bolt on top of cross member..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 09-21-2015, 11:25 AM   #9
padresag
there is nothing to be sorry about. it is just that a lot don't use it and there is quite a bit of info there. those 2 links from ther should be quite helpful
ron
