Old 09-16-2015, 07:03 PM   #1
jteck10
jteck10's Avatar
'62 305 v6 5.0l
Hey guys,
this might be a dumb question but i have an immense amount of grease and oil buildup on my engine. ive scoured the internet high and low and cant find where my oil filter canister is located in this engine. im trying to give her an oil change and have the new canister. i thought it would be on the drivers side just next to the distributor but im not seeing it. any help or pics would be greatly appreciated!
Also, my truck has an alternator from an 80's chevy. im looking to go back to an original generator for it instead. any pros/cons to doing this?
1962 GMC 2500 3/4 ton longbed stepside (currently w/flatbed), 4 on the floor, 305-V6-5.0L
jteck10 is offline   Reply With Quote
Old 09-16-2015, 08:04 PM   #2
duallyjams
duallyjams's Avatar
Re: '62 305 v6 5.0l
the oil filter canister is on the driver side bottom rear by the bell housing and it is big you can't miss it.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-16-2015, 08:36 PM   #3
jtrichard
Re: '62 305 v6 5.0l
STAY with the alternator FAR superior to any generator (There are reasons they dont use them anymore)
jtrichard is offline   Reply With Quote
Old 09-16-2015, 09:20 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Re: '62 305 v6 5.0l
Yep, stay with the alternator. Oil filter is on the driver's side near the bottom by the bell housing...go under the truck and you'll see it in an instance. lol Unless its gone somehow.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-16-2015, 10:59 PM   #5
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
great, thanks! ill try again tomorrow
Old 09-16-2015, 11:22 PM   #6
LVPhotos
LVPhotos's Avatar
Re: '62 305 v6 5.0l
Alternator with generator look from Speedway Motors.
http://www.speedwaymotors.com/Early-...-Amp,5867.html
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-17-2015, 04:38 PM   #7
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
i dont know what the hell is wrong with me, if im blind or my truck is so coated in grease i cant find the oil filter canister. i got underneath the truck to try and find it but came out with nothing. does anyone have any pictures or videos on where the heck this thing is? i thought i found it behind one of the valve covers but that can type canister had a long spout coming out from it that went straight down. any idea what that is? uploaded a few pics of what im working with. the replacement given to me from oreilly auto seems to be about as big as the larger part of the starter.
Old 09-17-2015, 05:01 PM   #8
cv65
cv65's Avatar
Re: '62 305 v6 5.0l
The pipe in the picture is a crankcase breather or road draft tube,If I remember right some early v6s did not have oil filters,it should be next to oil pan near bellhouseing {dark area in above picture} or a big can remotely located somewhere??
cv65 is offline   Reply With Quote
Old 09-17-2015, 05:04 PM   #9
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
so theres a possibility i just drain the oil pan and refill through the valve covers? no oil filter at all in the truck? that would sound about right since theres nothing the size of the starter around the oil pan or bellhousing
Old 09-17-2015, 05:08 PM   #10
cv65
cv65's Avatar
Re: '62 305 v6 5.0l
yea if you cant find the filter,was the filter they sold you a cartrige or a spin on?
Old 09-17-2015, 05:15 PM   #11
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
it was a cartridge, i believe this was the one
http://www.oreillyauto.com/site/c/de...0289&ppt=C0023
Old 09-17-2015, 05:24 PM   #12
cv65
cv65's Avatar
Re: '62 305 v6 5.0l
yea thats what it should look like ,would go upright in a canister next to oil pan rear of motor????? a long bolt running through the canister holds it on
http://www.curbsideclassic.com/wp-co...ne_crosssm.jpg see it other side of pan f rom starter
Old 09-17-2015, 05:38 PM   #13
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
i just ran outside to check and i dont have anything like that on the opposite side of the starter? i might not have an oil filter....
Old 09-17-2015, 06:00 PM   #14
cv65
cv65's Avatar
Re: '62 305 v6 5.0l
maybe thats why your motor is so oily just kidding hope you solve the mystery let us know
Old 09-17-2015, 06:21 PM   #15
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
haha maybe, hopefully not. ill get under there in a bit more detail tomorrow
Old 09-17-2015, 09:10 PM   #16
cv65
cv65's Avatar
Re: '62 305 v6 5.0l
Im told by my buddie that Im thinking of early straight sixes had no oil filter, so I don't know where yours went, would like to see whats where yours should be.
Old 09-17-2015, 11:15 PM   #17
jtrichard
Re: '62 305 v6 5.0l
jteck take a pic (with flash) straight up just in front of that tube on the drivers side
Old 09-18-2015, 10:33 PM   #18
kingsolver72
10/30/19
kingsolver72's Avatar
Re: '62 305 v6 5.0l
The canister for the oil filter will have a long 5/8ths bolt that runs straight through the middle of the canister. I'm not sure but, in the first picture, it looks like there is some kind of adapter plate with a knob for a lack of better word. First picture, left hand side, towards the middle.
Edit:After looking at it again I think that's where the filter is supposed to go. I think you're missing the canister.
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 09-18-2015, 11:34 PM   #19
BUILT2LAYFRAME
Re: '62 305 v6 5.0l
Mine is on the driver side of the engine by the oil pan. If I can figure out how to load a video, I'll post this one I just took.
BUILT2LAYFRAME is offline   Reply With Quote
Old 09-19-2015, 04:38 AM   #20
jtrichard
Re: '62 305 v6 5.0l
IN the first pic that is a PTO on the side of the trans.
Old 09-19-2015, 08:37 AM   #21
cv65
cv65's Avatar
Re: '62 305 v6 5.0l
I agree PTO, do you have a dump bed? The round thing around your drive
shaft on rear of transmission is your emergency brake.
Old 09-19-2015, 01:42 PM   #22
MusicMan70
MusicMan70's Avatar
Re: '62 305 v6 5.0l
Here is a canister oil filter housing location photo. Located on bottom left, this one is longer then the ones used in light duty trucks.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 09-19-2015, 02:02 PM   #23
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
i definitely dont have a canister there like this one. the truck once was a dump bed, and all the hydraulics and other stuff was cut out. ill go get a picture of the tubing with flash now as thats where i originally thought the oil filter would be
Old 09-19-2015, 02:19 PM   #24
jteck10
jteck10's Avatar
Re: '62 305 v6 5.0l
so i went and jammed my phone camera up next to the pipe and theres definitely no oil filter canister but what seems to be an adapter on top? sorry for the crazy amount of oil and grease. i was planning on doing an oil change after everything else ive done then taking her to have the engine bay and undercarriage cleaned thoroughly. thanks again for the help
Old 09-19-2015, 03:20 PM   #25
MusicMan70
MusicMan70's Avatar
Re: '62 305 v6 5.0l
I recall reading about a member on the 6066GMC forum who also said he did not have an oil filter; just a block off plate. Yours is the first I've seen. Looks like you can also see the electrical plug for the oil pressure light.
You can add on the canister type or try to find the factory spin-on filter unit from later years, but those can be tough to come by.
MusicMan70
1961 GMC Suburban
