Old 09-16-2015, 07:16 PM   #1
scuderia
scuderia's Avatar
292 Fuel Line
Anyone have a photo of the factory 292 fuel line from fuel pump to carb? Ordered one from inline tube and the one the sent looks like it would be for a 250.. unless the damn thing is supposed to run over the top of the valve cover instead of in front of it. thanks....
'66 C10 SWB
'64 C2 roadster
'38 Indian Scout Flattracker
'70 Triumph T120R
'81 Laverda Jota
scuderia is offline   Reply With Quote
Old 09-16-2015, 09:21 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Fuel Line
I bought brake lines from Inline Tube...had to readjust all the bends on every stinkin line because NONE of them fit right. Might just be that you have to adjust the bends on it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-16-2015, 10:16 PM   #3
scuderia
scuderia's Avatar
Re: 292 Fuel Line
I dunno TJ looks like it's 6" short!
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-16-2015, 10:43 PM   #4
jayoldschool
Moderator
Re: 292 Fuel Line
I would say it gets rotated counter clockwise (looking from front), passes under the PCV, and between the valve cover and stat housing.
jayoldschool is offline   Reply With Quote
Old 09-16-2015, 10:47 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Fuel Line
I'm almost sure that's the wrong line now...if you were to actually rout it correctly...the end that goes to the fuel pump would sit Exactly where a 230-250 fuel pump is mounted on the block.
Old 09-17-2015, 10:49 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 292 Fuel Line
I agree, that looks like a 194,230,250 line.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-17-2015, 10:52 AM   #7
scuderia
scuderia's Avatar
Re: 292 Fuel Line
yup, that's what I was thinking..
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-17-2015, 12:06 PM   #8
cv65
cv65's Avatar
Re: 292 Fuel Line
Id send inlinetube a email with picture,cant hurt
cv65 is offline   Reply With Quote
Old 09-17-2015, 12:23 PM   #9
pimpston65
pimpston65's Avatar
Re: 292 Fuel Line
when i walked in the inline store (since its here in michigan), i found the templates they have for bending lines may not be accurate. i had to bend the correct shape outta scrap tubing and then they bent up a new one with SS
pimpston65 is offline   Reply With Quote
Old 09-17-2015, 01:12 PM   #10
scuderia
scuderia's Avatar
Re: 292 Fuel Line
sent them the photos above yesterday but they haven't responded. guy on phone much less than helpful..... we'll see.
Thinking I'll fill it with glass bead and see if I can't form it into something that'll reach.
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-17-2015, 03:01 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Fuel Line
Maybe send that one back and make your own?
Old 09-17-2015, 05:10 PM   #12
60-66
60-66's Avatar
Re: 292 Fuel Line
Ive dealt with these companies in the past and if you send them yours as a sample , some shops will send you back a new one free for your efforts. They take returns.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-17-2015, 05:13 PM   #13
60-66
60-66's Avatar
Re: 292 Fuel Line
Also , my 1963 292 fuel line come into the fuel pump from the side while my 66 292s come into the top of the fuel pump. Several different versions to consider.
Old 09-17-2015, 10:11 PM   #14
scuderia
scuderia's Avatar
Re: 292 Fuel Line
Thinking that's what I'll do.. btw 292 ever have the fuel pump here (ebay truck says hi torque 292)??
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-18-2015, 10:30 AM   #15
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 Fuel Line
That's a 230-250 in the picture. No 292's ever had the pump there.
Old 09-19-2015, 10:20 PM   #16
aotte1
Re: 292 Fuel Line
Some pictures of 66' 292 fuel line carb to fuel pump.
Hope this helps. It is an original engine thought not to be rebuilt.
Les
aotte1 is offline   Reply With Quote
Old 09-20-2015, 12:50 AM   #17
scuderia
scuderia's Avatar
Re: 292 Fuel Line
Les
That's great! Thanks so much!!
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-20-2015, 11:36 AM   #18
scuderia
scuderia's Avatar
Re: 292 Fuel Line
Les
thanks again Les, I forgot to mention what an awesome engine that is!! If you ever end up selling it let me know. Don
'66 C10 SWB
'64 C2 roadster
'70 Triumph T120R
'81 Laverda Jota
Old 09-20-2015, 07:41 PM   #19
aotte1
Re: 292 Fuel Line
You are welcome, will let you know if I decide to sell. Plan on keeping.
Les
Old 09-20-2015, 08:11 PM   #20
jdl71
jdl71's Avatar
Re: 292 Fuel Line
I'm not sure what that is, but I don't think it's a 230/250 either. At least on mine the fuel line comes out of the front side of the pump not the top. Then runs forward, and under and behind the distributor before heading up. That doesn't look long enough for any of our applications.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 09-21-2015, 11:31 AM   #21
sigshooter
sigshooter's Avatar
Re: 292 Fuel Line
The carb pictured on the orange engine is from a 60-62 235, the line comes in the front.
The carb pictured in the later thread on the greasy green engine is correct for the 63-66 292. Line comes in the side
This will make a huge difference
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
