Old 09-16-2015, 09:20 PM   #1
J48chevy
J48chevy's Avatar
Battery holder in 1948
Has anyone relocated their battery under the hood? If so any pics. I am thinking of doing this since I will be putting aftermarket seats in and building some new seat frame braces so stock location under the body will be non accessible.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 09-16-2015, 09:22 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Battery holder in 1948
Use a frame mounted drop down battery box. Readily available and a bolt on.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-16-2015, 09:25 PM   #3
J48chevy
J48chevy's Avatar
Do most just bolt right onto the firewall then? Any additional bracing needed?
Old 09-16-2015, 09:52 PM   #4
Dan in Pasadena
No, a drop down is made to mount below the truck NOT on the firewall. There was no battery box in the AD engine compartments because there was so little space. That changed with the TF trucks but many of us with TF trucks move the battery to the frame for a cleaner, less cluttered look under the hood.
Old 09-16-2015, 09:55 PM   #5
J48chevy
J48chevy's Avatar
Thanks. I have the original one already mounted on the frame was just looking to possibly do one under the hood instead. I thought I had seen pics in the past of people moving it under the hood.
Old 09-17-2015, 06:02 AM   #6
Old Crow
Old Crow's Avatar
My wife's '54 has the battery on the firewall, high up on the passenger side. Not sure if there's any added bracing, but judging by the rest of the truck, I'd say not. Running a redtop in there, so not quite the weight of a regular battery.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 09-17-2015, 01:19 PM   #7
Iceburgh
Iceburgh's Avatar
If you have A/C and or a brake booster it will be tough to fit it onedr the hood.
You can move. Back on the frame but use heavy cable to the starter
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
