Old 09-16-2015, 10:29 PM   #1
Builtlikeatank634X4
big gap between fender and door
Here I go again
I just got these fenders .. Used .. Free .. And doing some placement trials when I notice linning up some bolt holes that I have the snake river canyon between the door and fender.
The inner fender wells are aftermarket and so is the radiator support .. Both inners measure the same length and even the fenders measure the same.
Something tells me I'm gonna be pulling the whole clip off again
Builtlikeatank634X4 is offline   Reply With Quote
Old 09-16-2015, 11:07 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: big gap between fender and door
I have never heard anything good about the repop parts, check bolt hole locations to original to make sure there not pushing fenders forward.
LT1 Burb is offline   Reply With Quote
Old 09-16-2015, 11:56 PM   #3
Builtlikeatank634X4
I wonder if the people selling the reproduction parts have ever put them together to see what there selling.
I still have the inner fenders so I can check the hole location but when in place the cab holes are to the rear of the fender holes and the inner well are more forward of the fender holes.
It looks like if I base my zero hole on the cab holes the gap will definitely be more in spec then it will be more about getting the light will and the whole nose section in line
Old 09-17-2015, 12:16 AM   #4
LT1 Burb
LT1 Burb's Avatar
That fender hole def tells the story, your inner holes are wrong, probably easier to elongate your fender holes, or buy OEM inners.
Old 09-17-2015, 02:09 AM   #5
Builtlikeatank634X4
Yep .. Found what's blocking line up and gonna have to lengthen the fender holes
Old 09-17-2015, 01:52 PM   #6
DLW
Some people have had to remove the inner fender front brackets and relocate them to get things to fit. I ended up not using the repop stuff I had, and either fixed or found replacement OEM stuff, just didn't want the hassle of the repops.
DLW is offline   Reply With Quote
Old 09-19-2015, 02:17 PM   #7
Builtlikeatank634X4
Your absolutely right .. These phony OEM as they call them are really a hassle to even line up holes with the mated piece from the same manufacturer .. I even bought this stainless inner and outer bolt kit that has no explanation of what goes where .. I mean come on .. Its like hey here's some bolts .. Good luck
