Old 09-17-2015, 10:46 AM   #1
Ronw435
Ronw435's Avatar
Rivets on front hub
Has anyone encountered a problem with the rivets, that I suppose, keep the brake drum attached to the hub? I have wheels that the rivets do not allow the wheel to lay flat against the hub. I have the original wheels that have indentations in the wheels that I would think allow the wheel to lay flat. Has anyone removed the rivets? I believe you would have to remove them to put new drums on correct? Can you remove the rivets and leave them off? I am attaching some pictures showing what I am talking about.
Ron
Ronw435 is offline   Reply With Quote
Old 09-17-2015, 10:49 AM   #2
Ronw435
Ronw435's Avatar
Re: Rivets on front hub
Ok sorry I looked and found that they can be removed. Thanks all
Old 09-17-2015, 11:43 AM   #3
1963c-10
1963c-10's Avatar
Yep...just grind them off.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-17-2015, 12:29 PM   #4
PGSigns
PGSigns's Avatar
Make sure when you grind off the heads you pull the drum and punch the pieces through. Had one come out many years ago and tear a few things up.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-18-2015, 08:09 AM   #5
Ronw435
Ronw435's Avatar
Thanks for the information. I ground them off and knocked them out. Now I hope the wheels are not ruined. I am wondering if this could be where some of the vibrations I am experiencing is coming from?
Old 09-18-2015, 09:43 AM   #6
PGSigns
PGSigns's Avatar
I would think the wheels are good. With them hitting it is possible to pull the wheel up out of square. That may cause a vibration.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
