Old 09-18-2015, 03:55 PM   #1
Jcox68rt
Power to brake light switch?
I was trying to diagnose a problem with my brake light switch in my 63 gmc swb fleet-side. There is a white wire and orange wire leaving the switch and goin up into the wiring harness. Simple enough, however, the orange only becomes hot when I turn my headlights on.. Seems like it should come on when the key is on or always hot. Right? I have two orange wires coming out of the other side of the harness and they both go to the same spot on the headlight switch. I'm pretty sure I can tell which one is the one that comes from the brake light switch because of the gauge. Should I remove it from the headlight switch and run it down to fuse panel in a non fused space that's available?
Am I over thinking this one?
Thanks in advance!
Jcox68rt is offline   Reply With Quote
Old 09-18-2015, 11:57 PM   #2
Jcox68rt
Re: Power to brake light switch?
No wiring gurus chiming in? I can always grab a constant hot from anywhere I guess or a hot from my ignition switch?
Old 09-19-2015, 12:37 AM   #3
66pnl
66pnl's Avatar
That orange wire should be hot at all times, it's the same circuit that powers the dome lamp. Comes from the fuse panel to the h/lamp switch then to the brake switch. Does the dome lite work.
66pnl is offline   Reply With Quote
Old 09-19-2015, 06:39 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
I did a print screen since this pic is from a pdf. Hope this helps.
Old 09-19-2015, 08:26 AM   #5
awbrown
The orange wire should be hot all the time , key on or not ... simply rewire it so it is hot and you should be fine .. if you have no brake lights after that repost .. if I remember , it comes off the headlight switch ,so the switch may be bad .. Mine was and I just picked a hot wire and spliced it in ...
awbrown is offline   Reply With Quote
Old 09-19-2015, 10:19 AM   #6
Jcox68rt
The dome light is missing, however I just bought a new one from brothers.
The screenshot does help, it shows those two orange wires coming off a hot leg of the headlight switch.
I have a new headlight switch to install also, that leg on the headlight switch according to the schematic above looks like it is a constant hot? So my switch is probably bad. It was doing some wonky stuff when I first got the truck. I'll change it out and see if it helps. If not I'll just grab a constant hot from somewhere, probably the fuse panel since it's right there.
Thank you all for the insight, help, and the schematic!
Old 09-19-2015, 12:31 PM   #7
The Rocknrod
Moderator
Ya I'd run a quick jumper from a hot lead to see if it works.
