Old 09-18-2015, 08:39 PM   #1
66 GWN
New member- ID Question
Hello everyone. Let me introduce myself. Been looking at this site and finally joined. So much information in one location.... It's great. I've called myself 66 GWN (Great White North). Obviously from North of the border. I purchased a 66 fleetside a couple of years back I found on a local classified add. I've always wanted one since my grandfather taught me to drive his 33 years ago. Thought it would be a great project for me and my sons to spend some time together rebuilding it and learning as we go. Well, the first two years we may have spent a week total on it. The kids were not interested at all. Times change and now all they want to do is work on the truck. Fun times.
Getting parts in Canada is very difficult and expensive we have found, so we are quickly becoming body work "experts".not sure what it is like south of the border but finding donor parts at a scrap yard is next to impossible. We have found one place near Toronto called bills truck shop which we have made a trip to a couple of times. Very helpful. Boy you could spend a lot of coin there..... Like a candy store ...
I'll post some pics of the beast soon.... No laughing....
Thanks for letting us join the club. Looking forward to share our experiences as we go.
Now for the Question:
How do I verify my engine, tranny and rear end?. PO told me it was not original. Said it was a 305 but didn't know what the tranny or rear end were..
66 GWN is offline   Reply With Quote
Old 09-18-2015, 09:01 PM   #2
cv65
cv65's Avatar
Re: New member- ID Question
Welcome to the gang, Youll like it here! Pictures are the way to get answers,It is true picture worth a 1,000 words!
cv65 is offline   Reply With Quote
Old 09-18-2015, 09:22 PM   #3
VonDog
VonDog's Avatar
Welcome to the forum! To find out what motor you have, you'll have to look on the driver's side of the motor to the rear and below the valve cover. There's a flat spot with numbers stamped on the block. Also, on the passenger side forward in front of the head is another set of stamped numbers that'll tell you the year manufactured. As for the tranny, is it a standard or automatic? How many bolts are on the rear diff cover?
60 K20, eaton HO52, T221, SM420, Dana 44 closed
78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open
05 Dodge Ram 2500 5.9 Cummins 4x4
VonDog is offline   Reply With Quote
Old 09-19-2015, 02:51 PM   #4
66 GWN
thanks VonDog. Ill take some pics and try to find numbers...
Old 09-19-2015, 03:57 PM   #5
66 GWN
Here are the pics and information. ID help please. First 2 pics are driver side rear block. "14010203" and what believe says"GM 5.0 L". The third pic is on the rear end (I know dirty). I count 8 bolts?. Also it is an automatic.
Any help would be appreciated..
66GWN
Old 09-19-2015, 04:07 PM   #6
cv65
cv65's Avatar
66GWN
http://www.castingnumbers.info/site/detail/136/14010203
Old 09-19-2015, 05:08 PM   #7
66 GWN
thanks for the info... any idea how to ID tranny and rear end?
Old 09-19-2015, 05:24 PM   #8
cv65
cv65's Avatar
Im sure someone will chime in about rearend and tranny ,pictures of truck inside and out help alot,could be 3 or 4 different trannys
Old 09-19-2015, 07:44 PM   #9
65sub
65sub's Avatar
Welcome GWN .The transmission can be identified by the shape of the pan. Just Goggle "chevy automatic transmission identification"
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 09-20-2015, 12:16 AM   #10
Captainfab
60-66 Nut
With the 5.0L on the block it is a 305. The rear end is a GM truck 12 bolt. As for the trans, you will need to ID it by the shape of the pan as 65sub said.
Old 09-20-2015, 07:57 PM   #11
66 GWN
Thanks everyone... should be able to ID the lot now..
Here's a pic of the truck as of today...
66 GWN
Old 09-20-2015, 08:04 PM   #12
jdl71
jdl71's Avatar
Looks like you've got some floor pan work in front of you, but other than that it looks pretty solid. Welcome.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 09-21-2015, 12:00 AM   #13
Captainfab
60-66 Nut
I didn't realize that you have an original automatic column. That column is for a Powerglide. Does the trans shift only once? if so it is a Powerglide.
