Old 09-19-2015, 10:38 AM   #1
bmchevy1979
bmchevy1979's Avatar
voltmeter swap
Ok I know it been asked thousands of times but I couldn't find anything 73-87 that was any good
So my question is how do you go about swapping a voltmeter in place of a ammeter in a 75 k20 I know you can't swap them out or you'll short out the truck but what wiring needs to be changed in order to do the swap. Links would be welcomed
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 09-20-2015, 12:05 PM   #2
bmchevy1979
Re: voltmeter swap
Bump
<Brandon>
Old 09-20-2015, 08:15 PM   #3
chengny
chengny's Avatar
Re: voltmeter swap
It's way more critical when changing from a voltmeter to an ammeter - than the other way around. To decommission your ammeter, just cut the two tap leads that feed the meter. They both should have inline fuses. One is connected to the firewall junction block and one comes off the starter solenoid. Like this:
In back of your instrument panel, dike off the other ends of those same leads (leave some extra wire to run to an ignition switched power supply and to the ground bus block.
The problem will be physically mounting the voltmeter into the ammeter spot. You will have to experiment a little with which leads go to which studs on the voltmeter (if backwards the meter will peg low) and also you might have to move the little clamp sockets to line up with the voltmeter.
chengny is offline   Reply With Quote
Old 09-20-2015, 08:38 PM   #4
bmchevy1979
Re: voltmeter swap
Ok thank you I believe I can make it work off of that I want to put my tach dash in and I prefer a voltmeter my 74 was a factory idiot light truck and I eliminated all the wiring except the illumination and turn signals when I put the aftermarket gauges in so I couldn't go off of that
<Brandon>
Old 09-20-2015, 08:48 PM   #5
bmchevy1979
Re: voltmeter swap
Double post
<Brandon>
Old 09-21-2015, 01:25 AM   #6
Baradium
Binder Rep
Baradium's Avatar
Re: voltmeter swap
That's the best way to get rid of the ammeter, since there's no reason to have the current going through the dash at that point.
To swap voltmeter in place of ammeter, all you HAVE to do is tie the two wires together that fed the ammeter and put them both to the hot side of the voltmeter and then run a wire to ground on the ground side and be done.
His way is better since it gets rid of the current from where it's not needed.
Baradium is offline   Reply With Quote
