Old 09-19-2015, 01:40 PM   #1
scott-wisc
scott-wisc's Avatar
1971 C/20 to 1/2 ton conversion
Will a-arms from a 78 suburban fit on a 71 pick up?
scott-wisc is offline   Reply With Quote
Old 09-19-2015, 11:20 PM   #2
72MARIO
72MARIO's Avatar
Re: 1971 C/20 to 1/2 ton conversion
Upper A arms yes. upper control arm shafts differ between 1/2&3/4 ton as do the lower ball joints size in the lower a arms. The lowers are different between 1/2&3/4 ton
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is online now   Reply With Quote
Old 09-20-2015, 08:15 AM   #3
scott-wisc
scott-wisc's Avatar
So if I pull the lower 3/4 arms off with the shafts, the 1/2 ton shaft/arm assembly will bolt on. Is that correct?
