09-19-2015, 02:25 PM | #1 |
C10 pro street HELP
Let me start first by saying my name is Josh and I'm new to the board! I have been building an 85 c10 for 2 years or so now and I'm to the point in the project where I need a axle that'll handle the power I'm putting to it because the 10 bolt isn't going to like it much. Any ways I joined this forum because I'm in the market for a ford 9 inch and wanted to talk to a few or as many guys as possible as to what width their axles are and what size rim and tires, C notch? Etc etc.... I have attached a pic of my truck as well, still under construction!
09-19-2015, 02:28 PM | #2 |
Re: C10 pro street HELP
Lil hopped up 355
09-19-2015, 02:41 PM | #3 |
If you're going pro street, any 9" will do since you have to narrow it anyways. If you're not going pro street, just upgrade to a 12-bolt. They're plentiful, cheap, and strong.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
09-19-2015, 02:49 PM | #4 | |
I'm definitely going 9inch route, I guess my question was more as to what width were guys narrowing them to? I'm thinking about buying a nice used posi chunk and then a housing and axle kit from mouser
JOSH: 85 SWB Mike Thompson 355/ FTI Turbo 400 |
09-19-2015, 03:03 PM | #5 |
No one can give you a measurement. You need to buy your wheels and tires first, then stick them in the wheel well to get your measurements.
09-19-2015, 03:12 PM | #6 |
That's why I asked for axle width and what tires and wheels... I was planning on having custom built wheels any way and wanted to start with axle and suspension and then have wheels built for exactly what I need. I was asking for people's axle width and rim and tire size to get an idea of how narrow of an axle I'm gonna need. Maybe I was putting my cart before my horse but I'd rather finish my drive train and suspension and have the truck on rollers than my $$$$ rims and tires sitting in a dusty shop while I piece together my axle and suspension.
09-19-2015, 03:33 PM | #7 |
Cruzzzn' Vet
Give these guys a call
http://currieenterprises2.reachlocal...earEndCampaign |
09-19-2015, 05:16 PM | #8 |
FWIW your 10 bolt will handle that 350 no problem. Plenty of parts available for them. If you are going the pro street route then you need to pick your wheels and tires first. Then set the rearend up to fit them. Its not hard to measure this at all but you cant go by anyone else`s measurements.
Anthony |
09-19-2015, 05:28 PM | #9 | |
09-19-2015, 05:34 PM | #10 | |
Anthony |
09-19-2015, 06:14 PM | #11 |
At the body shop.
And cost the same as 9" build and still have a better piece.
Cant beat the pinion support bearing for strength.
" That didnt make it any newer " " Dont antique the equipment " |
09-19-2015, 06:41 PM | #12 |
I wasnt saying the 9" isnt a stronger rear end. The point I was trying to make is that his 10 bolt will handle his engine just fine with the same upgrades the 12 bolt or the 9" would need as well.
Anthony |
09-19-2015, 07:06 PM | #13 |
The motor is a 355 all forged internals. ( Callies crank, compstar rods, and diamond domes) 6.00 solid lift cam, fuelie heads with crane gold rollers and valve springs, performer intake and a 750 Q series. 13:1 compression I just don't want to do all that work on a 10 bolt when I could find a nice used chunk and buy a housing and axle kit for around 900 and have a 9 inch so when the truck is complete and I get gear head fever and want a bigger motor I won't have to worry about the rear end for sure. My tranny is built for 1000 hp so I'm covered there as well. This motor was built by Mike Thompson racing engines down here in south FL. It's nothing to crazy but for a 23 year old with a house and family I feel I'm doing ok lol
09-19-2015, 08:47 PM | #14 | |
I can give you measurements on my truck based off my wheel and tire combo but if you are going with a different combo it will be meaningless. I have 15x14 rims with 4.5in back space and 29/18.5/15 Hoosier Pro Street radials. My stock leaf springs are moved inside the frame and up 3in. Axle is mounted above the leafs and frame is c-notched. My 9in housing is 47in wide and rear end fully assembled is 52.5in from wheel mounting surface to wheel mount surface. I would suggest buying the wheels and tires you want first, mock them in place then measure to get your rear end cut to fit. That is much easier than and cheaper than measuring for a wheel with an oddball back space or measuring wrong and the wheels don't fit.
John 82 Chevy Silverado 350ci/TH350 |
09-19-2015, 08:54 PM | #15 |
Again, the point of my post which seems to be missed is that the OP claimed the 10 bolt would not handle his engine. Regardless of what he uses it will have to be upgraded, even a stock 31 spline 9". for strength you cant beat the 9". That is not what I was saying.
J Knight, good looking truck. Might consider doing that set up on my 85. Always loved the pro street look.
Anthony |
09-19-2015, 09:03 PM | #16 | |
09-19-2015, 10:27 PM | #17 |
Thank you!! This is exactly what I was thinking or should I say knew..?? But I'm glad I stand corrected on how to go about putting this rear end together. Looks like I'll be saving a lil more money for rims and tires. I wanna do a pro street look with a modern twist. Like a 22x14 out back with a 20x9 up front. Nothing that hasn't been done but it's a look I do like.
09-20-2015, 12:17 AM | #18 |
Hold on there bud. You claimed the original 10 bolt would not hold the power which is wrong. I corrected that but no where did I say anything about costs. I even mentioned that if you were planning to cut something down to start with a 9" so dont start making your hat fit tighter. Your getting a little cocky about the wrong thing. You posted a question, you didnt like being corrected. Not my fault. Good luck.
Anthony |
09-20-2015, 01:19 AM | #19 |
I would like to see a dyno sheet,I don't see a 355 making over 400hp unless your spraying it big time.The other thing is big wheels with rubber band tires will never hold enough traction to break a 10 bolt.If you throw a set of real slicks on it and push it hard you might break the 10 bolt but thats a hard might.
09-20-2015, 02:05 AM | #20 | |
Anthony |
09-20-2015, 02:12 AM | #21 |
At the body shop.
I will say if you don't hook it, you will never break it.
Traction and wheel hop violence break stuff. Burnouts wont.
09-20-2015, 02:42 AM | #22 |
^^^^ What he said.
"If you don't break traction, you'll break something else."
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
09-20-2015, 10:11 AM | #23 | |
09-20-2015, 10:14 AM | #24 | |
09-20-2015, 10:38 PM | #25 | |
Anthony |
