But Found Her 25yrs Later!
![]() Join Date: Oct 2010
What Are These Pieces?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
Re: What Are These Pieces?
mounting bracket and an adjustment bracket, but for what?
ron |
The mounting bracket I'm pretty sure came from the 66 292.
The adjustable bracket I'm not sure. Maybe from the 79 donor I had years back? I think I'll post them in the 'Pay it Forward' thread.
![]() Join Date: Aug 2013
I think you're correct about the bracket with the adjustment slot.
60-66 Nut
![]() ![]() Join Date: Mar 2007
I believe the bracket on the lower left is the lower AC compressor bracket for a '68 and earlier small block.
Yep, you guys are right.
AC mounting bracket on left. The one on the right: 1971-mid-80's Small-Block Chevy Power Steering to Compressor Mount Support Bracket Usually found on later early to mid-80's cars & trucks w/A6 Compressors. FOR POWER STEERING BRACKET THAT HAS NO SLOTTED ADJUSTMENT IN THE BRACKET ITSELF. Type-3 w/adjustment slot. Driver-side mount/long water pump. (Glass beaded & repainted semi-flat black.) $25.00 1969-70 SBC V8 A/C Compressor Mount Brackets
I believe the top one is the Z-Bar for the clutch linkage.
