Old 09-19-2015, 07:07 PM   #1
ChrisDollins
ChrisDollins's Avatar
Drivers rear locking up
Ok, I have a weird problem going on. Before I order an adjustable proportioning valve and throw this valve, I would like for yall to look it all over and see what you think. I did the disc conversion last summer and I don't remember it doing this. Right now the drivers side rear brake seems like the only one working. It is very grabby, but it does release when you let off. I've bled everything probably 6 times and I am getting good fluid out of the front. I adjusted the brake way in and it did better. But it would still lock up first, but it would let the fronts at least start to work. But after driving it a few times, it's back to using only that one. Thw adjuster had moved back out. Whats going on? Any pointers? Here are a few pics.
Chris
ChrisDollins is offline   Reply With Quote
Old 09-19-2015, 08:54 PM   #2
ChrisDollins
Re: Drivers rear locking up
A little bit more info. I tried to use a c-clamp to hold the little pin into the valve, but couldn't get it to work. But I did still get a good amount of fluid out of the bleeders on the front. I checked to make sure the small surface shoe was towards the front. Can't think of anything else.
Old 09-19-2015, 09:37 PM   #3
T and S
T and S's Avatar
might have to install an adjustable proportioning valve.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 09-19-2015, 10:37 PM   #4
ChrisDollins
That's pretty well where I'm at. When I deleted ABS on the '00 Z28, I went with an adjustable one. Really liked it. Only thing that has me concerned is why is it just the drivers rear and not both.
Chris
Old 09-21-2015, 09:10 AM   #5
T and S
T and S's Avatar
another thought - maybe the adjuster on the other side is not working, may be worth while to pull it apart and check.
Old 09-21-2015, 01:04 PM   #6
luvbowties
luvbowties's Avatar
Cool Re: Drivers rear locking up
Chris
You said, "But after driving it a few times, it's back to using only that one. Thw adjuster had moved back out." Sounds like driv side adjuster is working correctly. Also, sounds very much like your pass side brake is not working because it is not being adjusted along with driv side. Check adjuster on pass side. May still have to install an adjustable propor valve to reduce fluid going to rears, but you need to get both rears synchronized first.
Sam
luvbowties is offline   Reply With Quote
Old 11-14-2015, 11:04 PM   #7
ChrisDollins
Just incase anyone else has a similar problem, I did figure it out today. I had planned on putting the adjustable p-valve on yesterday, but realized I didn't have all of the fittings I needed. And the more I thought on it, the more I thought maybe the front seal on the primary piston in the master cylinder was bad. So this morning I replaced it, and that fixed it.
At first my parking brake cable has been froze up, so a friend thought that may be causing the one rear wheel to engage first. I finally got the cable loose and adjusted it to enough slack and made sure not to set it until new cable comes in. Then I had thought maybe the adjusters were causing trouble, so I pulled the automatic adjusters out and ran both adjusters almost all the way in where they wouldn't drag at all. One semi-quick stop in the gravel and it drug the drivers rear. It was like the fronts were getting nothing, but they would bleed. They just wouldn't get enough pressure before the pedal started engaging the rear brakes in the master cylinder. The pressure was being bled off back into the reservoir. The master cylinder was bought new when I did the disc brake swap like two years ago. Wasn't expecting it to be bad. I will get the rears adjusted right and the automatic adjusters back in when I put the adjustable p-valve in during winter. Crazyness.
Chris
Old 11-15-2015, 11:04 PM   #8
derail
derail's Avatar
Just curious, when you were bleeding the brakes, did you get fluid out of the back? I know that you said the fronts bled normally. Sounds kind of like a problem I'm having.
derail is offline   Reply With Quote
Old 11-16-2015, 08:54 AM   #9
ChrisDollins
I did. That's what was getting me so bad. All four bled good. After working around on the pass rear a little more, I was able to get it to lock up in the gravel along with the fronts.
Chris
Old 11-16-2015, 12:00 PM   #10
MikeN
MikeN's Avatar
If you're not getting fluid out of the rears, check that rubber flex line over the differential housing. Very common for those lines to deteriorate over time and get completely clogged up.
MikeN is offline   Reply With Quote
