8" dual diaphragm booster
I need a 8" dual diaphragm booster for my truck.. Was wondering what vehicle came with that stock so when I go to the parts house I can order it.. The kids nowadays only know what the computer tell them.. Thanks for any info
Re: 8" dual diaphragm booster
Because of the offset bracket and linkage that a '67-'72 uses the easiest thing to do is just buy a complete aftermarket one. I think I paid about $200 for mine on eBay with a new master cylinder.
#3 | |
I have a wilwood master cylinder I bought and wanna run on the truck.. I'm trying to find the part locally but worst case I'll order from summit or jegs later today.. Thanks |
#4 | |
I bought one from Advanced auto for a 1993 C-1500. Had to modify the rod to match the original bracket setup and make up a plug to fill the hole in the master, but it works very nice. You can make any GM booster fit with some minor mods.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
If I understand you correctly, you're looking for an OEM parts store 8" dual diaphragm booster?
If so, as far as I know, only Mopar, and maybe some Fords ran that style of booster in an OEM application. If that holds true, it is not a bolt in application for GM. The aftermarket boosters have been modified to fit GM applications as it's just a casing and holes, the insides function the same. You'll need to purchase an aftermarket setup for your truck. |
#6 | |
Yea I was looking for a oem parts store, no luck so I ordered 1 from summit and should be here Tuesday ... Thanks |
Sleep-Deprived
Old thread, but Google 54-71011 for OEM reman units of the 8" dual diaphragm booster just for future reference (while they last, anyway)
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
Like this one?
![]() IIRC late 70's Corvettes used something very close to the one in my pic. I think I had to reference the number on my old one to replace it, but it wasn't an aftermarket-only part.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
![]() Join Date: Dec 2013
I got one 15 or so years ago off a Chevy wrecker for my 70 C10 but never used it.
What is the benefit over regular boaster? Thanks |
Old member
I bought a aftermarket chrome 8". I figured it would look good and perform well!m I do not like it at all. It feels weak compared to the old 11" one that I took off the truck.
![]() Old setup: New setup: ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
