Old 09-20-2015, 01:43 PM   #1
Houston Ben
Houston Ben's Avatar
Lowering and Pinion angle
Hi all,
86" C10 with 5.3 and 6L80 lowered truck 2/4 with belltech. I have a wobble I thought I had figured out but it is still there. Spindles are stock and I thought the drivers side was the problem but I put new bearings on and all checked out. I have talked about this before and here is the thread
http://67-72chevytrucks.com/vboard/s...d.php?t=666758
I am about to purchase shims but I also want to change the angle of the transmission so I can match the 3* down and 3* down as in this picture on the top regarding leaf spring rear-ends.
To do this, I would need an 8* shim in pinion and raise the trnas approx 1/4 inch.
For anyone who has a 2/4 lift, what did you do for the angle or did you even need to do anything? Does any of this make sense? am I on the right path? Or should I not move the trans and just shim as noted in the provided link ? This angle stuff is confusing the heck out of me and this wobble is driving me nuts!
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 09-27-2015, 08:58 AM   #2
65standard
65standard's Avatar
Re: Lowering and Pinion angle
I just lowered mine and set it up like in picture #2.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
