Old 09-20-2015, 01:44 PM   #1
BMERDOC
BMERDOC's Avatar
Door Panels, Woodgrain Inserts and Trim.
I have a bunch of panels to get rid of. I have two pair of trim rings and multipe woodgrain inserts. If you are interested in a set of panels let me know and I'll tell you more about them. Door panels start at $80/pr shipped and up to $150/pr. Two steel panels don't match. I'll take $35/ea shipped for them. Trim rings are $40/pr shipped. I have four pair of woodgrain insert and three right side inserts. Two of those right side panels are really nice and will include the trim ring. $40/pr shipped or $40 shipped for the right side panel/trim set.
Panels $80 and up per pair
Sgl steel panels: $35/ea
Trim rings: $40/pr
Inserts: $40/pr
Inserts with trim: $40/set
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-20-2015, 01:46 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Door Panels, Woodgrain Inserts and Trim.
Panels
Nick Carter
Old 09-20-2015, 01:53 PM   #3
BMERDOC
BMERDOC's Avatar
More panels
Nick Carter
Old 09-20-2015, 01:57 PM   #4
BMERDOC
BMERDOC's Avatar
Even more panels
Nick Carter
Old 09-20-2015, 07:07 PM   #5
davischevy
davischevy's Avatar
Do you have a pair of 72's with a really good left side panel? I don't need the insert or trim.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-20-2015, 07:31 PM   #6
BMERDOC
BMERDOC's Avatar
I have two sets that, as far as I can tell, are perfect. Just need a good scrubbing and the inserts swapped out.
Nick Carter
Old 09-20-2015, 08:29 PM   #7
davischevy
davischevy's Avatar
How much for the black, shipped to 72601?
other Larry
Old 09-20-2015, 08:34 PM   #8
BMERDOC
BMERDOC's Avatar
Either the black or blue ones would be $150 shipped. They are my best ones.
Nick Carter
Old 09-20-2015, 08:41 PM   #9
Willowrun
Willowrun's Avatar
I just need a nice pass. side woodgrain insert. Is that an option?
Old 09-20-2015, 08:43 PM   #10
davischevy
davischevy's Avatar
Could you please give me till the middle of the morning tomorrow? I need to check and make sure I don't already have a set.
Thanks,
Larry
other Larry
Old 09-20-2015, 08:49 PM   #11
BMERDOC
BMERDOC's Avatar
Take your time. I'll hold them and give you enought time to check. Anyone else is next in line.
Nick Carter
Old 09-21-2015, 11:47 AM   #12
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I would take the black, if they don't have extra holes, no broken tabs and are original-not painted. thanks, frank
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 09-21-2015, 01:38 PM   #13
BMERDOC
BMERDOC's Avatar
Frank, I promised Larry first dibs. you are next in line. They are in great shape and I have no reason to suspect they've been painted. I'll check and double check again to verify that.
Nick Carter
Old 09-21-2015, 02:08 PM   #14
davischevy
davischevy's Avatar
I will take the black ones. PM payment info.
Larry
other Larry
Old 09-21-2015, 02:23 PM   #15
davischevy
davischevy's Avatar
Payment sent to Bmerdoc@yahoo.com.
Ship to;
Davis Construction
attn.; Larry
212 Coy Street
Harrison, AR 72601
other Larry
Old 09-21-2015, 02:49 PM   #16
BMERDOC
BMERDOC's Avatar
Thanks Larry!
Nick Carter
Old 09-21-2015, 04:07 PM   #17
72tutone
What is your best pair/pics of a left and right side woodgrain insert?
Shipped to 63385 please.
Thanks-
Matt
72tutone is offline   Reply With Quote
Old 09-21-2015, 08:01 PM   #18
BMERDOC
BMERDOC's Avatar
Sorry Willowrun, I completely missed your post. I can send you one of the three inserts in the second pic (right side) for $30 shipped.
Nick Carter
Old 09-21-2015, 08:21 PM   #19
BMERDOC
BMERDOC's Avatar
72tutone, left side inserts are questionable. How good are you expecting the left ine to be?
Nick Carter
Old 09-21-2015, 08:31 PM   #20
Apache67
How much for a pair of your good steels for a 67 at zip 36360?
Apache67 is offline   Reply With Quote
Old 09-21-2015, 08:46 PM   #21
BMERDOC
BMERDOC's Avatar
Apache, the best ones I have are the last pic in post #3. They have texture paint in them and some mild surface rust. They have two holes in each one just below the window crank and door opener. They are about an 1/8th inch in diameter. I don't see any dings. Most of the lower screw holes are in great shape but the rearmost on the driver's panel is slightly elongated. $80 shipped.
Nick Carter
Old 09-21-2015, 09:56 PM   #22
Willowrun
Willowrun's Avatar
That sounds good to me. I'll take the one that looks best to you. Please send me paypal info.
Thanks!
Old 09-22-2015, 08:01 AM   #23
72tutone
Thanks for checking. Im going to pass
Old 09-26-2015, 10:23 AM   #24
BMERDOC
BMERDOC's Avatar
Bump
Nick Carter
Old 10-05-2015, 09:54 AM   #25
BMERDOC
BMERDOC's Avatar
Ttt
Nick Carter
