Old 09-20-2015, 07:15 PM   #1
Mathew21
Mathew21's Avatar
Steering column spring question
OK I feel stupid but I took my steering wheel off months ago with intentions of replacing the turn signal canceling switch. Now I'm finally putting it back together. Where does the spring go? Is it sandwiched between the wheel and the turn signal canceling cam? My truck is a 1966 C20 with an automatic column.
Thanks, Matt
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 09-21-2015, 09:35 AM   #2
Mathew21
Mathew21's Avatar
Re: Steering column spring question
I thought the spring was in between the wheel and the turn signal switch. But I cant get the wheel on the with the spring their.
This is the diagram I was using as a reference. Below are are pictures of my column.
Old 09-21-2015, 12:01 PM   #3
vince1
I thought it went below the lower bearing and you should be able to see it from under the hood.
vince1 is offline   Reply With Quote
Old 02-01-2016, 09:41 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think that heavier spring goes under the lower bearing - bottom of column - inside engine compartment.
The softer spring goes in blinker housing.
66 C20 Service Truck:
Old 02-01-2016, 10:13 PM   #5
Mathew21
Mathew21's Avatar
I figured it out but Thanks!
Old 02-04-2016, 02:33 PM   #6
LostMy65
LostMy65's Avatar
I'm still trying to figure everything out.
Did you have that smaller upper spring, or did you do something else?
Old 02-04-2016, 10:56 PM   #7
Mathew21
Mathew21's Avatar
When you posted that picture I was thinking I don't remember putting any spring in my column. I was thinking am I missing that spring? I put my column back together last fall I know I ended up with no spring under the horn button. But I also could't get horn to work right. Every time I turned the wheel it went off. I just wanted to get the truck on the road so I unhooked my horn and figured I would deal with it this spring.
Old 02-04-2016, 11:00 PM   #8
LostMy65
LostMy65's Avatar
Yeah, I still haven't resolved this question.
Http://67-72chevytrucks.com/vboard/s...d.php?t=696930
