Old 09-20-2015, 10:03 PM   #1
lovemmth
lovemmth's Avatar
Brake time
Hi all I just finished my front disk kit. Now I am going to start on the lines and master cylinder. I am going to the junk yard in the am. My thoughts are I am going to get a booster/master cylinder and proportioning valve from a 71-87 c10. Then use the junk master cylinder as a core. Will this work.
lovemmth is offline   Reply With Quote
Old 09-21-2015, 12:21 AM   #2
Captainfab
60-66 Nut
Re: Brake time
That will work if you don't mind the look of those booster brackets and drilling holes in your firewall. Also you will not have as good a connection between your booster/master and the pedal bracket than if you were to use the correct factory mounting holes.
All of my booster brackets use the factory mounting holes.
Old 09-21-2015, 01:45 PM   #3
donthekawguy
donthekawguy's Avatar
Re: Brake time
I used capt's bracket and a new MC and booster from a 71 Impala. Works great and looks great. I did forget to paint the MC and booster but I'm taking the front everything off and will have to wire wheel it and give it a coat of POR15.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-21-2015, 09:36 PM   #4
lovemmth
lovemmth's Avatar
Re: Brake time
Thanks guys This is what I have on the truck now. What about adding a 71 impala m/c and proportioning valve. I know I will also have to change the rod. Name:  nexus2 220.jpg
Old 09-22-2015, 12:52 AM   #5
Captainfab
60-66 Nut
Re: Brake time
You can use the '71 Impala booster and master, or any of the compatible boosters listed in post #183 of the '63-'66 booster bracket for sale thread. You do not have to use the master cylinder that originally came with a given booster. You just need to use a master that is correct for the length of the intermediate pushrod.
Old 10-03-2015, 05:56 PM   #6
lovemmth
lovemmth's Avatar
Re: Brake time
Hey Captain I have another question for you or anyone else. I went to the junk yard today and found a few master cylinders and brake boosters 82-02 s10. Three questions all the master cylinders were plastic. Can they be changed with a metal one of the same year? Also the proportioning valves had what looked like some kind of plug. And would I need to use one of your mounting brackets with this setup? Thanks
