09-21-2015, 07:33 AM | #1 |
Heater Hose routing
I have a 1979 C10 with a 350, I have an easy way and a hard way to run my hoses. The easy way is to the radiator and to the water pump. Will this work?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
09-21-2015, 08:18 AM | #2 |
Re: Heater Hose routing
They are supposed to go front of intake and radiator I don't believe you will get hot coolant from water pump I actually think that is a return on some older models
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-21-2015, 01:49 PM | #3 |
In the Forgotten far North.
Your heater is fed from the intake manifold (5/8" nipple)then returns to either the water pump or the radiator.
If your radiator has provision for a 3/4" heater hose hook up, use that and plug the water pump hole with the proper size plug.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
09-21-2015, 02:07 PM | #4 |
I do have the nipple on the radiator, I just do not have access to the port on the intake. you can see the front passenger port is blocked by my fuel line, and the driver side port is blocked by the radiator hose. I can raise the carb and make adjustments, and it looks like I will have to. That is why I wanted to check. thanks guys
Chris
09-21-2015, 02:09 PM | #5 |
another pic
09-21-2015, 07:46 PM | #6 |
Maybe something like this: http://www.globalindustrial.com/p/pl...FQ6HaQod3SkIpg installed on the driver's side pointed back toward the carb. Install the normal hose barb and run the hose between the thermostat housing and the carb.
09-21-2015, 07:55 PM | #7 |
The port in the radiator and intake manifold are the hot water supply to the heater, use only one. The water pump is suction and pulls the coolant from the heater. You should be good if you use the radiator as supply and water pump for return.
09-22-2015, 01:29 AM | #8 | |
The COOLANT IN THE RADIATOR AND WATER PUMP IS ACTUALLY COLDER THAN THE COOLANT IN THE ENGINE/INTAKE Going from water pump to heater and back to radiator will not get you any anything but headaches and frustration wondering why your cab isn't getting very warm in the winter.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 09-22-2015 at 01:54 AM. |
09-22-2015, 01:48 AM | #9 | |
You can find the hose at Napa just make sure the short side is at 6-8" long to clear over your valve covers and the short end of the other onto the heater core, cut to length and join the 2 hoses together with the union. And clamps....don't forget the clamps.
09-22-2015, 07:23 AM | #10 |
thanks for the ideas, I thought about using the ports in the back, but they are smaller than the front, will see how it goes. Will keep you posted
09-22-2015, 08:52 AM | #11 |
I found a 1” spacer on ebay for pretty cheap Should I get one with a single square opening, or one with four (4) circles to match the bottom of the carb? Is there any difference?
http://www.ebay.com/itm/1-Phenolic-C...e10bd5&vxp=mtr http://www.ebay.com/itm/1-Phenolic-C...cf17c6&vxp=mtr Thanks
09-22-2015, 11:20 AM | #12 |
It almost sounds like your best bet, or at least easiest, would be a 90 degree heater hose fitting on the passenger side.
09-22-2015, 11:32 AM | #13 |
just swapped a 350 in for 6 it had hose connections on the pump. There was a port in the bottom off the block .Ran from intake to core to bottom block. Needed heat here couple weeks ago. Nothing. had bought a new rad it had 3/4 nipple. The intake port your blocking to core return rad good heat now 10 below well see?
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
09-22-2015, 05:13 PM | #14 |
I think I need to raise it up any way to help with my vacuum line anyways. Which one you guys think will be the best?
09-22-2015, 11:36 PM | #15 |
Because your intake isn't fully open, go with the 4 hole spacer.
