09-21-2015, 09:08 PM | #1 |
WTB 1/2 ton 4x4 rear axle u bolt plates
Not sure of the correct term. I am looking for a pair of the backing plates for the rear axle housing that the Ubolts go through. and if I remember correctly. There was a semi flat bracket on the tops of the spring that had a circle hole that sat around the center bolt and notches for the top of each u bolt to sit in.
Thanks |
09-21-2015, 10:01 PM | #2 |
Re: WTB 1/2 ton 4x4 rear axle u bolt plates
