![]() Join Date: Feb 2009
Looking for a super duper OEM vapor canister, for 71.
71 Chevy
NOS or like new. These have three connections for fuel emissions: 1. Fuel Tank 2. CARB 3. PCV
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#2 | |
The Older Generation
Re: Looking for a super duper OEM vapor canister, for 71.
- Here are a couple of older threads on the subject. Especially the second one but you have to read the whole thread.... http://67-72chevytrucks.com/vboard/s...d.php?t=572954 http://67-72chevytrucks.com/vboard/s...d.php?t=569115 Not sure how much is still relevant.... LockDoc
#3 | |
Thanks Doc. I spent hours researching just last night. The NOS (17063011) in the first thread is not the original set-up for the 71, though would probably work. It looks to be an 1980 and later part.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-22-2015 at 06:00 PM. |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I have a couple...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Hi Iron. How many miles you figure on that first one? Is the charcoal still good? Should be nice and loose.
Does it have the drain on the bottom? If so, I believe the bottom comes off. Thank you.
The first one is a pic of my daily driver and she's an actual 116,000 72 LWB C-10 (still mounted and venting the gas tank)...The second pic is out of my other 72-C-10 with 154,000 miles on the trucks clock but that canister came out and went under the bench 5 years ago. Both are in excellent shape with a fiber disk shaped filters on the bottom. Neither one appears to have been molested nor do they appear to "come apart". They are identical other than the missing cap in the second photo. I'm pretty sure that cap is in the shop...Somewhere? I do know that with a good cleaning, an exacto-knife used with ginger diligence, these units can be disassembled, cleaned and restored with an overnight soak in Armor-All, refilled with activated charcoal and glued back together for a new looking canister...PS. The bottom of both of these has a single molded plastic rod that runs across the bottom diameter of a 3-1/2" opening...
I'll give it some consideration Iron. I would need to cut it open, but the canister looks nice. The top on mine was thrashed by battery acid.
