09-23-2015, 01:30 AM | #1 |
Wrong year yes but does anyone know??
Does anyone know if in 1964 chevy offered the 327 small block in their c10 trucks? everything I am finding says the first year it was offered was in 1965 but the guys says they were offered so its just a 1964 327 that he is replacing the original with as in trucks the engine and the truck didn't match they are more so if its a correct year that matches the truck. Now I was aware of that but in checking I cant see any case or any site that says 327 was in any trucks before 1965....this is a bad match right?
thanks for any comments and help you guys offer Last edited by kcsa75; 09-23-2015 at 08:17 AM. |
09-23-2015, 01:50 AM | #2 |
Re: Wrong year yes but does anyone know??
if you have access to one of the old service manuals it should tell you in the front what all engines were available
1969 Chevy C10 2wd stepside longbox |
09-23-2015, 01:51 AM | #3 |
I don't have one and been looking to down load one and no luck as of yet
09-23-2015, 01:56 AM | #4 |
Did you ask on the 1960-1966 Board? They might be more knowledgeable about that vintage.
09-23-2015, 02:10 AM | #5 |
1964 did they have a 327 SB
I know the truck falls outside of the years but does anyone know if in 1964 chevy offered the 327 small block in their c10 trucks? everything I am finding says the first year it was offered was in 1965 but the guys says they were offered so its just a 1964 327 that he is replacing the original with as in trucks the engine and the truck didn't match they are more so if its a correct year that matches the truck. Now I was aware of that but in checking I cant see any case or any site that says 327 was in any trucks before 1965....this is a bad match right?
thanks for any comments and help you guys offer |
09-23-2015, 05:19 AM | #6 |
Re: 1964 did they have a 327 SB
327 didn't come out till 1966 In the truck
1964 had the 283.. a danm fine engine if i my say so the kick panel (Drivers foot well side) should have a card with engine classes
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
09-23-2015, 05:26 AM | #7 |
09-23-2015, 06:04 AM | #8 |
The 283 was an option for 1960 to 64, then in 1965 a 283 or 327 was an option.(according to the internet)
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
09-23-2015, 07:13 AM | #9 |
Here is the generic info packet for a '64, from the GM Heritage Center archives:
https://www.gmheritagecenter.com/doc...olet-Truck.pdf It shows all of the available powertrain offerings - pg 7 (as well as all other available options). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-23-2015, 09:10 AM | #10 |
Thank you that was what i was seeing on the net too but before assuming someone is lying or or wrong i wanted to make sure i was write. Thank you so much.
Was the 283 engine any good or did it have a good power utput? |
09-23-2015, 09:28 AM | #11 |
But Found Her 25yrs Later!
283 was a very reliable engine.
But I think the torque from a 292 inline 6 was a better fit for a truck.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
09-23-2015, 09:40 AM | #12 |
My copy of Motor's Truck Repair Manual shows a Taskmaster V8 327 available as early as 1962 from GM.
09-23-2015, 10:19 AM | #13 |
From what I know the 327 was available in the big rigs in the early 60's then in 66 it was available in the C10's. My 64 only had the 283 as a v8 option.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-23-2015, 10:42 AM | #14 |
For the 327 , 1962 is the first year yes, but it was only available in Big Trucks , C40? C50 C60 , same through 1964 . This picture is from the 1964 Data book. 283 was it for C10.
This picture is from the 1965 Truck Data book , 327 becomes available in c20 and C30 up to C60 . For 1966 its available for ALL C10 and up.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
09-24-2015, 06:54 AM | #15 |
As everyone has said 64 c10 had the 283 as an option not a 327. But from memory there was a small journal 327 that had the same casting number as a 283.
09-24-2015, 10:23 PM | #16 |
327 was available in pickups in late 65 and 66. Same for the TH400 transmission although it was only available in 3/4 tons.
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 Last edited by sodly; 10-09-2015 at 10:40 PM. |
