09-23-2015, 02:49 AM | #1 |
Wheel Bearing Grease
Hello,
I would like to put some new Wheel Bearings on my 66 c10. Now i need new Wheel Bearing Grease. Is the Grease from Timken (Allstar) the right one ? Can i use this Grease for the Balljoints to ? Or is there a better Grease ? Thank you verry much. Greatings from Germany. Nils |
09-23-2015, 11:02 PM | #2 |
Re: Wheel Bearing Grease
Maybe this will help
http://www.hemmings.com/hmn/stories/...feature27.html
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
09-23-2015, 11:58 PM | #3 |
I for one am guilty of using one or two different types of grease for everything. Damn! The wife is gonna kill me when she finds out that I have to take it all back apart in the garage again!
In all seriousness though, I used Mobil 1 Synthetic EP grease on my bearings and Amsoil synthetic waterproof EP grease for all my tie rods, u joints, trailer bearings and other general purpose applications. Call me lazy ( and uneducated about grease) but it's worked out ok for me. I can't even think of having 20 different cartridges and 1 lb tubs all over.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
09-24-2015, 08:20 AM | #4 |
Hello, thanks for the fast answers.
The Problem is that the most greases don´t send to Germany (over sea). In Germany I could get the Grease from Valvoline. The Multipurpose EP 2. Knows anybody this Grease ? Thanks Nils |
09-24-2015, 02:59 PM | #5 |
Moderator
If you can find Valvoline grease these guys should be able to find Moly Forified Grease:
http://www.valvoline.com/our-product...purpose-grease Wilhelm Schwenker GmbH & Co.KG Hahler Str.140 32427 Minden, Germany Detec Handel GmbH Kasseler Landstr. 1 37213 Witzenhausen, Germany Autechna Autoteile GmbH, Korbach Nordring 21 34497 Korbach, Germany Autechna Autoteile GmbH, Frankenberg Berleburgerstraße 32 35066 Frankenberg, Germany Autechna Autoteile GmbH, Stadtallendorf Egerländerstraße 1 35260 Stadtallendorf, Germany
09-25-2015, 12:18 AM | #6 | |
Greetings from Germany Nils |
