Old 09-23-2015, 09:08 AM   #1
oldblue92
oldblue92's Avatar
2003 2500hd Flashing Service Engine Light
Hi guys I have a 2003 Silverado 25000hd 6.0 with 170,000. Always on top of maintainance. Yesterday on my way home my truck slightly rev'd and the engine light started to flash then went off a minute later. Im going into town later to check out the code. Any Ideas? Thanks a bunch guys
oldblue92 is offline   Reply With Quote
Old 09-23-2015, 09:50 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 2003 2500hd Flashing Service Engine Light
When the check engine lamp flashes, it indicates that there is a misfire bad enough to cause damage to the cat. converter.
My guess is you will have misfire codes. Either P0300-P0308.
95 S_Trucker is offline   Reply With Quote
Old 09-23-2015, 09:52 AM   #3
BMERDOC
BMERDOC's Avatar
^^^Yup
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-23-2015, 11:01 AM   #4
oldblue92
oldblue92's Avatar
WHat could cause the misfire code?
Old 09-23-2015, 11:26 AM   #5
BMERDOC
BMERDOC's Avatar
Its usually an ignition problem. Bad coil, worn/bad plug, bad wire. Sometimes it can be fuel or cylinder related (loss of compression) or a vacuum leak near that cylinder causing a lean miss.
Nick Carter
Old 09-24-2015, 03:14 PM   #6
oldblue92
oldblue92's Avatar
any recomendations on a quality coil and plugs?
Old 09-24-2015, 04:55 PM   #7
95 S_Trucker
AC Delco. for plugs. AC Delco/Delphi for the coil.
Before you throw parts at it, what code did you have?
