Painting my engine
I am in the process of cleaning my engine and getting all of the grease off. Once I finish I am planning on painting it the original dark green( it's a 261). Will I have to use engine enamel or high heat paint or will regular spray paint work because I have some in the right color. If not where can I buy high heat dark green paint?
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
Re: Painting my engine
I would go with high temp paint just to be safe. Ive seen it at autozone and advanced. Im sure O'Reillys carries it too. When i did mine i also used a high temp primer.
Moderator
![]() ![]() Join Date: Aug 2011
I wire wheel'd every nook and cranny on my engine and went with POR-15 engine paint. Following instructions to the letter. The paint never did burn off even around the exhaust ports. On my next block I am going the same route.
But if your going to do it in the engine compartment I'd go with VHT hi-temp spray paint. Just remember that a clean surface is the difference between success and failure.
Post Whore
![]() Join Date: Mar 2013
VHT has a Bunch of paint available. Had good luck with them so far.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
This guy has some very good paint. I used it a Chevy 6.
http://www.hirschauto.com/ENGINE-ENA...info/EE-QUART/ Hugh |
