Old 09-12-2003, 08:40 AM   #1
76bonanza
76bonanza's Avatar
cleaning plugs
What is the best way to clean spark plugs?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 09-12-2003, 09:21 AM   #2
1FaastC10
1FaastC10's Avatar
go to your local auto zone, etc and say "i need a set of (insert brand and part number here) spark plugs." $15.00 at the most for a standard set.
1FaastC10 is offline   Reply With Quote
Old 09-12-2003, 09:55 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
1FaastC10 is right. Unless you get platinum plugs, they should be about $10 for a set of 8.
When I clean up plugs, I usually just keep it in the spark plug socket and hit it with a wire brush. If it is oily, I'll shoot some brake cleaner on it.
Replacement is really best, though, as cheap as they are.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-13-2003, 10:07 AM   #4
77bowtie
Yep! Brake cleaner & wire brush. Re-gap them before putting them back in. I have also been known to file the electrode if its rounded off a bit, just to flatten it at the tip.
77bowtie is offline   Reply With Quote
Old 09-13-2003, 02:14 PM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If you need or want to clean inbetween the electrode and ground strap you can use carboard. It has to be like a cereal box type carboard tho. It is abrasive enough to clean and not really hurt anything.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-13-2003, 05:34 PM   #6
swervin ervin
You get what you pay for
swervin ervin's Avatar
Cleaning spark plugs is nothing but a waste of time, IMO. Buy a new set and be done with it.
If your engine is causing dirty plugs on a regular basis, it's time for some engine work. In this case, it may save a few bucks to clean them.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
