Old 09-12-2003, 10:32 AM   #1
WB72
Before and After
WB72's Avatar
pan hard bar
could I just cut and weld mt pan hard bar when I lower my truck 3 or 4 inches?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 09-12-2003, 10:34 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
I just made the bracket on the frame reach where it needed to, didnt alter the strength of the bar.
sneakysnake is offline   Reply With Quote
Old 09-12-2003, 03:28 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
It's high strength steel. You can weld it, but you don't want to unless you get it heat-treated.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-12-2003, 04:25 PM   #4
chaptr2
chaptr2's Avatar
You can buy an adjustable pan hard bar from one of the venders. I don't think it is that expensive and it will make the fit much easier to achieve.
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 09-12-2003, 06:25 PM   #5
chevykid1969
chevykid1969's Avatar
Sorry to but in but do you need a new one when lowering 4 or 5 in the rear
chevykid1969 is offline   Reply With Quote
Old 09-12-2003, 06:27 PM   #6
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Yes for 4 inches or less... If you go 5 or more go with the whole tracking arm kit. If i could do it all over again I would have just bought the kit since i'm going to lower my rear more in the near future.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-12-2003, 06:46 PM   #7
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
I cut mine sleeved it and welded it. Just as strong, maybe stronger. Cost me $2
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 09-12-2003, 07:06 PM   #8
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
If my truck was lowered I would cut and weld. Or take it to some who can.... High strength steel???? Says what and who?
67Fleetsidedream is offline   Reply With Quote
Old 09-14-2003, 05:14 PM   #9
WB72
Before and After
WB72's Avatar
Is it really High Strength Steel?
66,000 miles.
Alberta, CANADA
Old 09-14-2003, 06:42 PM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I don't know how strong they can be, when i bought the GMC mine was both bent and broken in two.
Old 09-14-2003, 06:57 PM   #11
pissonNOS
senior member
pissonNOS's Avatar
what are the panhard bars ? im confused now
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 09-14-2003, 07:22 PM   #12
Longhorn Man
If you were to look from direcly behinde the truck (coil models only) there is a bar goinf grom the top of the diff to the frame. That is the panhard bar.
Old 09-15-2003, 01:32 AM   #13
pissonNOS
senior member
pissonNOS's Avatar
thats runs from the front to back of the vehicle right . not litteraly the length of the vehicle but the same direction?
69 GMC bagged
Old 09-15-2003, 09:51 AM   #14
WB72
Before and After
WB72's Avatar
It really goes from the Rear end (Differential) to the frame. The pan hard bar goes from the drivers side of the frame to just about the center of the diff. The width way, not the length.
66,000 miles.
Alberta, CANADA
Old 09-15-2003, 01:55 PM   #15
pissonNOS
senior member
pissonNOS's Avatar
thank you the ones i described are control arms no?
69 GMC bagged
Old 09-15-2003, 02:11 PM   #16
lukecp
Formerly yellow72custom
lukecp's Avatar
Yup...you described contorl arms (also known as trailing arms )
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-15-2003, 05:22 PM   #17
Red68
Red68's Avatar
I lowered my truck 4" and installed an adjustable bar, from what I could tell there was very little difference compared to the old one, maybe 1/2" or less in length. If I had it to do over again I probably would not replace it and save a few bucks.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 09-15-2003, 05:41 PM   #18
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Yeah, just anything over 6" is when it needs it. I lengthened mine 1 & 1/4" over stock. But mine is bagged and probably 8 or 9" lower than stock.
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 09-15-2003, 05:43 PM   #19
chevykid1969
Ok i am stuck. i a getting ready to lowwer mine 3/5 do i need to get a panhard bar or not . they seem to be a bit pricy.
Old 09-15-2003, 06:05 PM   #20
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
That's right at the brink of a yes or no.
I say no.
Lower it then see how far it shifts over
68 chevy money pit
51 chevy belair
95 Honda 900RR
